grid dblclick
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Re: grid dblclick
Post by Claudio Ricardo »
Hi... I use:
Function Grid_X_On_DblClick	// Called from Grid_X OnDblClick
LOCAL nPos := GetProperty ("Win_X" , "Grid_X" , "Value")	// Get selected Row
LOCAL aArray_Item := GetProperty ("Win_X" , "Grid_X" , "Item" , nPos)	// Get array with all selected row, values
LOCAL cCellValue := ""
	cCellValue := aArray_Item [1]		// [1] = number of col i need get value ( between 1 to last col )
Return cCellValue
franco
Re: grid dblclick
Post by franco »
Claudio Thanks,
I can not make work but I what use to get row column is.
local Npos := form_1.grid_2.value, mitem := ''
if nPos[1]  = 2 .and. nPos[2] = 2
	// I am in row 2 column 2 .  My grid uses tables not arrays.
	// I want to know what this cell has in it  example "500" so I can compare to the table the grid is linked to before saving grid.
mitem := form_1.Grid_2 "cellvalue"   ???????????
All The Best,
Franco
Canada
Claudio Ricardo
Re: grid dblclick
If I don't misunderstand what you want is to compare the original value of the table shown in the grid, with the value after the user changed it in the grid...
If so you can try this:
PUBLIC paArrayGrid := {}	// In the Main.prg
When double click in grid, first read cell value and store in public array:
Function Grid_2_On_DblClick	// Called from Grid_2 OnDblClick
LOCAL nRow := GetProperty ("Form_1" , "Grid_2" , "Value")	// Get the number of selected Row with double click
	paArrayGrid := GetProperty ("Form_1" , "Grid_2" , "Item" , nRow)	// Here i store in the public array the values of all columns to selected row
											// don't matter if load from array or table Item have complete row values
	// Here is the code that enables the user to change the value of the grid...
When the user changed the cell value and wants to save it, you check if the new value in grid is correct before saved in table...
Function Save_New_Value
LOCAL nRow := GetProperty ("Form_1" , "Grid_2" , "Value")	// assuming it didn't change row when saving the new value
LOCAL aArray_Item := GetProperty ("Form_1" , "Grid_2" , "Item" , nRow)
	// I suppose you need compare column 2 to old value stored in public array with new value in aArray_Item
	Do Case		// or If Else, Switch
		Case paArrayGrid [2] == aArray_Item [2]
			// action for equal values
		Case paArrayGrid [2] <> aArray_Item [2]
			// action for different values... Etc.
	EndCase
	// Here one function to reload / refresh grid data...
Sorry for my bad english or if something I did not understand :oops:
franco
Re: grid dblclick
Post by franco »
Your english is great, we just code a bit different. What I need is not cell position but what is in cell of cell position.
In row 2 col 2 of my grid is 500 before saving.
the value in the table for grid in row 2 col 2 is 400
I NEED TO KNOW THESE 2 VALUES BEFORE SAVING THE GRID. I KNOW TABLE VALUE. i NEED A VARIABLE WITH GRID VALUE.
LOCAL nPos := GetProperty ("Form_1" , "Grid_2" , "Value")	// your way of get selected row and column
Local aCell := Form_1.Grid_2.value                                   //  my way of get  selected  row and column
LOCAL aArray_Item := GetProperty ("Form_1" , "Grid_2" , "item" , nPos)	// Get array with all selected row, values
LOCAL cCellValue :=   ???        // I want a variable with what is in row 2, col 2         cCellValue should be 500
                                             // the value in the table for grid in row 2 col 2 is 400
msgbox(npos)                     msgbox is  2  2
msgbox(aCell)                     msgbox is  2  2
msgbox(aArray_item)          msgbox is empty at this time no value shows up. I want 500
msgbox(cCellValue)  SHOULD BE 500.
I hope this makes sense
All The Best,
Franco
Canada
franco
Re: grid dblclick
Post by franco »
I got it finally.
Local cCellValue :=  Form_1.Grid_2.CellEx (aCell[1] , aCell[2])
All The Best,
Franco
Canada
Re: grid dblclick
Remember that grid.value returns array of cell position or row number
franco
Re: grid dblclick
Post by franco »
Yes, thanks Mol for thought.
Local aCell := Form_1.Grid_2.value,   AcellValue, nOQty, nNQty
nNQty := Form_1. cCellVaGrid_2.CellEx (aCell[1] , aCell[2])
select pinv_it
Go Form_1.Grid_2.Recno               //sets the pinv_it file to grid
nQQty := pinv_it->qty
If aCell[2] = 2 .and. nOqty <> nNQty                           //grid col 2 = selling qty
          select Inv                                                        // must change inventory qty on hand.
          seek pinv_it->Item_no
          if found
             if rlock()
                replace onhand with onhand + nOQty-nNqty    // must check if odl > new or new > old first.
                unlock
select pinv_it
   // continue on
All The Best,
Franco
Canada
franco
Re: grid dblclick
Post by franco »
I can not get former post to work.
The grid onchange always goes though calling procedure twice.
I needs more work.
All The Best,
Franco
Canada
Claudio Ricardo
Re: grid dblclick
Sorry I did not consider that you used cell navigation, so I put nRow as in a standard grid. .oops.
I already know that it can be done both ways, it is that I have gotten used to the Set and Get property.
Re: grid dblclick
not sure if this match what you want
When DblClick you have "This."
- This.CellRowIndex
- This.CellColIndex
- This.CellRow
- This.CellCol
so you can use "This."
STATIC isRunning := .F.    // Field-wide STATIC must be on TOP of *.PRG
   ON DblClick DoEdit(This.CellRowIndex, This.CellColIndex)
PROCEDURE DoEdit(nRow, nCol)
LOCAL xVal
   IF isRunning = .T.
   isRunning := .T.
   IF .NOT. EMPTY( nRow ) .AND. LEN( aData ) >= nRow
      xVal := aData[ nRow ] [ nCol ]
      // Do what you like
   isRunning := .F.
