VLC for HMG
Re: VLC for HMG
chrisjx2002 wrote: Sun May 02, 2021 8:13 am I uninstall and reinstall vlc. Always the same problem. I take a look in the registry and I find :
Ordinateur\HKEY_CLASSES_ROOT\TypeLib\{DF2BBE39-40A8-433B-A279-073F48DA94B6}\1.0\0\win64
Not the same as yours.
you show me your "TypeLib" but i like to see "CLSID" and "ProgID"
Computer\HKEY_CLASSES_ROOT\CLSID\{9BE31822-FDAD-461B-AD51-BE1D1C159921}\ProgID
so search for 9BE31822-FDAD-461B-AD51-BE1D1C159921
which VLC Version did you install :?:
have you "check" Option AciveX & WebPlugin when Install VLC :?:
older x64 IMHO did not work but that Version 3.0.13 ( 3.0.12 ) did work for me under 64 Bit
chrisjx2002
Re: VLC for HMG
Post by chrisjx2002 »
Hello,
I search for search for 9BE31822-FDAD-461B-AD51-BE1D1C159921. And I find it.
But I have always the same problem. The VLC version is the one you have 3.0.12. I am working with windows 10 64 bits last update.
There is a problem with PLAYLIST
vlc plugin suite1.jpg (38.01 KiB) Viewed 8621 times
vlc plugin suite.jpg (93.27 KiB) Viewed 8621 times
vlc plugin.jpg (94.23 KiB) Viewed 8621 times
vlc clsid.jpg (111.98 KiB) Viewed 8621 times
Re: VLC for HMG
chrisjx2002 wrote: Mon May 03, 2021 4:45 pm I search for search for 9BE31822-FDAD-461B-AD51-BE1D1C159921. And I find it.
your last Snapshot is what i mean.
it looks all OK ... hm
can you "open" Registry Tree of last Snapshot to see what is in "ProgID"
Line 282 show this
      ::oPlaylist := oControl:playlist
IMHO it does not work while oControl fail, not :playlist
i guess ActiveX is not create ... hm
try this
      ::oControl := oControl
      IF EMPTY(oControl)
         MsgInfo("VLC not correct installed")
         QUIT
in Source Code you can change
"VideoLAN.VLCPlugin.2"
to
"{9BE31822-FDAD-461B-AD51-BE1D1C159921}"
and try it again
did 32 bit Version work :?:
chrisjx2002
Re: VLC for HMG
I try again.
With 32 bit version it works!
With 64 bits always problem. I try with "{9BE31822-FDAD-461B-AD51-BE1D1C159921}"instead of "VideoLAN.VLCPlugin.2". Same problem.
When I change the code, I have not the message "VLC not correct installed" but the same error. See screnshot.
I search the progid in regedit. See screenshot.
vlc progid.jpg (71.82 KiB) Viewed 8585 times
Re: VLC for HMG
chrisjx2002 wrote: Tue May 04, 2021 8:22 am With 32 bit version it works!
mystery ... 32 Bit is working and 64 Registry "seem" OK but does not work ... :o
try to change
      IF EMPTY(oControl)
         QUIT
into
      IF VALTYPE(oControl) <> "O"
         MsgInfo("VLC Object was not create")
         QUIT
if you now get MsgInfo() than ACTIVEX Object was not create ... but i don´t know why :(
... ANSI or UNICODE IDE
chrisjx2002
Re: VLC for HMG
I made the test. I don't have the msginfo but the same error. Very strange.
Re: VLC for HMG
Aquí, solo probando...
No tengo instalado el VLC !. (Win10/64)
Here, just testing ...
I don't have VLC installed !. (Win10/64)
chrisjx2002
Re: VLC for HMG
I have perhaps found the problem. I compile with hmg 32 bits and not 64 bits. It is probably why it does not work.
chrisjx2002
Re: VLC for HMG
Got it! It was a problem of 64 bits compilation. Now it works!
Re: VLC for HMG
chrisjx2002 wrote: Wed May 05, 2021 12:18 pm I have perhaps found the problem. I compile with hmg 32 bits and not 64 bits. It is probably why it does not work.
that can be the Problem when try to use 64 Bit Component with 32 Bit :D
