Hardware for Blood Pressure Measure ?
- AUGE_OHR
did somebody use Hardware to measure Blood Pressure Measure which can send Data to my xBase App ?
how does it work with mobile Phone ? which Data Format can be used ?
- dragancesu
Re: Hardware for Blood Pressure Measure ?
No, but some models can connect with mobile like
https://www.omron-healthcare.com/eu/blo ... _IT_2.html
and have aplication from PlayStore
- AUGE_OHR
Thx for Answer.
at that Website i found Hardware but it seem it store Data "internal" ... and only 100 Records.
i like to store 10 Years and measure at least each Hour so i need much more Space for Data
i have see Diary App using Smartphone and Bluetooth ... that i like to have for Desktop / Table PC
Thx for Answer.
- dragancesu
I don't know what you do but this is a bit of a field of medicine
Blood pressure measurement is done 1-2 times a day, measuring every hour is unnecessary, and it is not very pleasant for everyone
This is for home conditions, in the hospital it is different
The other thing is the pulse measured continuously
Hi Jimmy!
As you wrote on google groups, bluetooth sometimes uses virtual COM port. Install drivers and test if new COM port appears in Device Manager.
Communication via serial ports is easy, but you need to know protocol
- AUGE_OHR
but in Hospital they have a Monitor that automatic measure every Hour.
those Monitor use a lot of Cable so you can´t "move" without lost connection.
now we have a lot of "Fitness Tracker" which can get those Information and Data can be transfer via Bluetooth.
i agree that those Data are not "exact" but it will give a "long time overview" when have a lot of Data
so the Question is : how to use Bluetooth with harbour to receive Data.
you are right that normal you just measure Blood Pressure twice a Day.dragancesu wrote: ↑Fri Feb 05, 2021 6:19 am Blood pressure measurement is done 1-2 times a day, measuring every hour is unnecessary, and it is not very pleasant for everyone
- AUGE_OHR
i "think" i got a "Keyword" to search for : BluetoothAPIs.dll
also this UUID seems to be need
BT Device must be visible in Hardware Manager and it must have 2 x "Bluetooth Serial Port (SPP)"
while "out-going" is easy the Problem seems to be "in-coming" Data
"out-going" like Printer or Head-Phone seems not to use Event so it is like DLLcall()
"in-omming" like my external GPS-Tracker seems to "wait" for Event to send/receive Data
there are a lot of "Smart-Watch" which can be used as "Health-Tracker"
Guid SerialPortServiceClass_UUID = new Guid("{00001101-0000-1000-8000-00805F9B34FB}");
did someone use a "Smart-Watch" like this ?Apple Watch Series 6
Samsung Galaxy Watch 3
Garmin Fenix 6 Pro Solar
Apple Watch SE
Huawei GT 2 Pro
Honor GS Pro
Fitbis Semse
Oppo Watch
Polar Grit X
Withings Scanwatch
Try
https://github.com/libusb/hidapi
Make .dll or .a with mingw make (mingw32-make)HIDAPI is a multi-platform library which allows an application to interface with USB and Bluetooth HID-Class devices on Windows, Linux, FreeBSD, and macOS. HIDAPI can be either built as a shared library (.so, .dll or .dylib) or can be embedded directly into a target application by adding a single source file (per platform) and a single header.
- zolysoftsolutions
are you amazing. I just recieved communication protocol from our bank, and I have no ideea to communicate on serial port.
POS installed, test communication is okay, but here the movie is ended.
_______________________________
Open eyes for you!
Open eyes for you!
Put this protocol here or send me via email mol @ pro (dot) onet (dot) pl
