48 x Color, not Gradient
i like to set Backcolor 48 Label "like Gradient" ...
1st Label should be YELLOW and 48st Label BLUE so other Label should have Color between
how :idea:
how to convert this HEX Color to RGB :?:
0x01800000
Re: 48 x Color, not Gradient
Some years ago Grigori Filatov posted sample with colored grid in this way. Try to search, maybe it will help you
Say we have R1, G1, B1 as the first color and R2, G2, B2 as the second Color.
DiffR = ( R2-R1)/48
DiffG = (G2-G1)/48
DiffB = (B2-B1)/48
For every cell you can increment this DiffRGB.
Just an idea. :)
Visit
C:\MiniGUI\SAMPLES\Applications\RGBMixer
AUGE_OHR wrote: Sat Nov 21, 2020 8:26 am hi,
how :idea:
Hi Jimmy,
Please take a look for the sample code below (it is for MiniguiEX, of course). :arrow:
 * (c) 2020 Grigory Filatov <gfilatov@inbox.ru>
STATIC nLabelObj := 1
FUNCTION MAIN
   LOCAL y, x, cSymbol, pos, h := 16
   LOCAL aDummy := Array( 48 )
   LOCAL ColorBegin := HMG_RGB2n( YELLOW )
   LOCAL ColorEnd := HMG_RGB2n( BLUE )
   DEFINE WINDOW Form_1 ;
         WIDTH 400 ;
         HEIGHT 840 ;
         TITLE '48 Colors Demo' ;
         MAIN
      y := 20
      x := 10
      FOR EACH cSymbol IN aDummy
         pos := hb_enumindex( cSymbol )
         @ y, x LABEL ( 'Lbl_' + hb_ntos( nLabelObj++ ) ) WIDTH 360 HEIGHT h ;
            VALUE pos CENTERALIGN VCENTERALIGN ;
            FONTCOLOR HMG_n2RGB( GradientColor( HMG_RGB2n( BLACK ), HMG_RGB2n( WHITE ), 1, 48, Pos ) ) ;
            BACKCOLOR HMG_n2RGB( GradientColor( ColorBegin, ColorEnd, 1, 48, Pos ) )
         y += h
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
STATIC FUNCTION GradientColor( ColorBegin, ColorEnd, AMin, AMax, APosition )
   LOCAL B
   LOCAL B1, B2, B3
   LOCAL E
   LOCAL E1, E2, E3
   LOCAL P
   B := COLORREF_TO_ArrayRGB( ColorBegin )
   B1 := B[ 1 ]
   B2 := B[ 2 ]
   B3 := B[ 3 ]
   E := COLORREF_TO_ArrayRGB( ColorEnd )
   E1 := E[ 1 ]
   E2 := E[ 2 ]
   E3 := E[ 3 ]
   IF AMax - AMin <> 0
      P := ( APosition - AMin ) / ( AMax - AMin )
      P := 0
RETURN B1 + Round( ( E1 - B1 ) * P, 0 ) + hb_bitShift( B2 + Round( ( E2 - B2 ) * P, 0 ), 8 ) + hb_bitShift( B3 + Round( ( E3 - B3 ) * P, 0 ), 16 )
The result screen is showed below:
Hope that useful :idea:
