Set Initial Focus Color
Red2
Post by Red2 »
I have what I trust is a very simple question about a Browse of a .DBF on a form.
I want the the Browse's very first (topmost) row to have and show focus. So, in the form's OnInit I issue the following:
DBSelectArea( "MyItems" )
MyItems->( dbGoTop() )
// Then:
SetProperty( "DataBrowse", "BrowseItems", "Value", recno() )
// The top row now has focus.
Fine so far. However the selected (first) row's background color is an undesirable a very light grey.
But now whenever the user selects a row then that row clearly shows its focus
by its dark blue BACKGROUND color.
My Question:
I want that first row (with focus) to be initialized showing with the dark blue background color.
What command(s) can I use to force this dark blue background color?
Thank you for you kind assistance.
Red2
SALINETAS24
Re: Set Initial Focus Color
Post by SALINETAS24 »
Red2 wrote: Mon Oct 26, 2020 3:47 pm I have what I trust is a very simple question about a Browse of a .DBF on a form.
// Then:
My Question:
Red2
DataBrowse.BrowseItems.setfocus
Red2
Post by Red2 »
Hi SALINETAS24,
Gracias por su amable respuesta. Agregué la línea que sugirió como sugirió.
Desafortunadamente, el formulario no se compila. Crea:
C: \ HMG-Official \ DataBrowse_OnInit.PRG (69) Error E0030 Error de sintaxis "error de sintaxis en '.'"
Luego probé la siguiente sintaxis:
SetProperty ("DataBrowse", "BrowseItems", "SetFocus")
Si bien se compilará, esto no ayuda con mi problema de fondo azul oscuro.
Cualquier sugerencia adicional sería realmente apreciada.
English ==============================================
Thank your for your kind response. I added the line you suggested as you suggested.
Unfortunately the form does not compile. It creates:
C:\HMG-Official\DataBrowse_OnInit.PRG(69) Error E0030 Syntax error "syntax error at '.'"
I then tried the following syntax:
SetProperty( "DataBrowse", "BrowseItems", "SetFocus" )
While it will compile this does not to help with my dark blue background problem.
Any further suggestions would really be appreciated.
Thanks again
Red2
SALINETAS24
Hola Red, estaría bien que mandases algo más de código, por ver donde y como tienes defino del DATABROWSE.
A mi la instrucción que te pase me funciona correctamente, en un GRID eso si.
Un saludo.
hi Red,
SetFocus is NOT a Property, it is a Method ;)
      Domethod( cForm, cGrid, "SetFocus" )
Red2
Post by Red2 »
Hi SALINETAS24,
Gracias (otra vez). Como mencioné, simplemente estoy examinando un .DBF en una TAB en un FORM.
Este formulario fue creado usando el IDE de HMG. No hay GRID aquí.
Claro que puede, aquí está el código de definición BROWSE (no GRID).
DEFINE BROWSE BrowseItems
    ROW    52
    COL    22
    WIDTH  950
    HEIGHT 388
    VALUE 0
    WIDTHS { 200, 150, 100, 160, 74, 67, 170 }
    HEADERS {"Mfg. Name", "Type", "Size / Dim.", "Model", "Item Len.", "OAL", "Serial Number"}
    WORKAREA My_Items
    FIELDS {"My_Items->MFG_NAME", "My_Items->TYPE", "My_Items->SIZEDIM", "My_Items->MODEL", "My_Items->ITEM_LEN", "My_Items->OAL", "My_Items->SERIAL_NBR"}
    FONTNAME "Arial"
    FONTSIZE 9
    TOOLTIP ""
    ONCHANGE Nil
    ONGOTFOCUS OnPageSelection( "My_Items" )
    ONLOSTFOCUS Nil
    FONTBOLD .F.
    FONTITALIC .F.
    FONTUNDERLINE .F.
    FONTSTRIKEOUT .F.
    ONDBLCLICK DataBrowse_BrowseItems_OnDblClick()
    ALLOWEDIT .F.
    ALLOWAPPEND .F.
    ONHEADCLICK Nil
    ALLOWDELETE .F.
    HELPID Nil
    VALID Nil
    VALIDMESSAGES Nil
    LOCK .F.
    VSCROLLBAR .T.
    DYNAMICBACKCOLOR { bkItems, bkItemType, bkItems, bkItems, bkItems, bkItems, bkItems }
    DYNAMICFORECOLOR Nil
    INPUTMASK Nil
    FORMAT Nil
    WHEN Nil
    INPUTITEMS Nil
    DISPLAYITEMS Nil
    BACKCOLOR NIL
    FONTCOLOR NIL
    IMAGE Nil
    JUSTIFY Nil
    NOLINES .F.
    READONLYFIELDS Nil
    HEADERIMAGES Nil
END BROWSE
Cualquier ayuda es muy apreciada.
ENGLISH =================================
Thank you (once again). As I mentioned I am simply Browsing a .DBF in a TAB on a FORM.
This form was created using HMG's IDE. No GRID here.
Sure can, here is the BROWSE (not GRID) definition code. (SEE ABOVE)
Any help is greatly appreciated.
Red2
Red2
Post by Red2 »
Thank you Jimmy,
Of course you are correct, it is a Method.
I have tried putting
DoMethod( "DataBrowse", "BrowseItems", "SetFocus" )
both before and after:
In both cases my BROWSE does not initialize with the row in FOCUS having dark blue BACKCOLOR.
It does not seem that this should be that hard in Harbour. Ideas anyone?
Again, thanks to all!
Red2
did you have
SET BROWSESYNC ON
i do "setFocus" just before ACTIVATE
Red2
Post by Red2 »
Hi Jimmy,
Thank you very much. Yes, in my Main.PRG (SET BROWSESYNC ON) exists.
When:
// Comes immediately before
activate window DataBrowse
there is still no change to the BACKCOLOR of the row in focus in that BROWSE.
QUESTION: Is that what you were suggesting regarding "just before ACTIVATE"?
I am grateful for your kind help. What am I missing here?
Kind regards,
Red2
Browse have "Keyword"
VALUE <nValue> ]
so you can use Recno() at Create and must not use SetProperty()
