Hi guys, thank you but I think I did not made myself clear:
I have multiselect grid with few hundred lines (<1000), scrolling through the grid I select a 2 lines (COMPARE and change some value or whatever), save them and THEN
I want to save line-number of the grid, rebuild the grid with the changed values and direct to line I was.
Without multiselect this is possible (i've done before) so the focus has to be set on the previous line.
// simple grid, x is row selected
SetProperty('Form_1', 'Grid_ADRESSEN', 'Value', x ) // this works
/* documentation says:
GRID (Standard): Numeric (Row Selected).
GRID (Multiselect): Numeric Array (Rows Selected). ////////// this is the one I need
GRID (CellNavigation): Numeric Array (Row and col selected).
THIS I TRIED:
// SetProperty('Form_1', 'Grid_ADRESSEN', 'Value', {1,1} )
// SetProperty('Form_1', 'Grid_ADRESSEN', 'Value', {1} )
// SetProperty('Form_1', 'Grid_ADRESSEN', 'Value', (1) [1] )
// SetProperty('Form_1', 'Grid_ADRESSEN', 'Value', (1,1) )
// SetProperty('Form_1', 'Grid_ADRESSEN', 'Value', i )
SOME GIVE RTE, SOME COMPILE-ERROR AND SOME DO NOTHING....
Hope this is clear enough....
