Strange behavior of HMG IDE
Re: Strange behavior of HMG IDE
Gracias por el aviso, voy adicionar el timer y recompilar.
Such a problem also appears in ANSI IDE.
Another problem is that IDE is very aggressive about function keys. I always use Total Commander, when F5 is used for copy files. Many times, when I press F5, action is taken by minimized IDE and compilation starts. Also F2 and F8 cause problems.
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi Dr Claudio,
srvet_claudio wrote: Tue Sep 01, 2020 5:37 pm Hi,
please replace old Unicode IDE for this version and test it.
Despite the new build, HMG_Ide it´s still generating the same errors... :cry:
Salamandra, Brazil
Este error se genera de forma aleatoria o cuando se realiza alguna operación en particular?
martingz
Post by martingz »
Dr. Claudio, me pasa lo mismo, despues de varias compilaciones en mi caso, tengo que entrar al administrador de tareas y darlo de baja
Ok gracias.
Otra pregunta, alguien se acuerda a partir de que version de hmg empezó a aparecer el problema ?
salamandra
Hola Dr Claudio,
srvet_claudio wrote: Thu Sep 03, 2020 2:16 pm Este error se genera de forma aleatoria o cuando se realiza alguna operación en particular?
Es totalmente aleatorio y aparentemente no hay ningún gatillo que inicie el problema.
Salamandra, Brazil
Ok gracias.
salamandra
:) Hi Dr Claudio,
good news about this problem?
Salamandra, Brazil
I'm sorry, but I'm out of time to work on it.
The IDE is a very large project with a lot of code.
I'm just one more user.
