Strange behavior of HMG IDE
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hello everyone,
I'm developing a small project and I'm experiencing some problems with HMG Ide Unicode.
It seems to be some question related to memory (I suppose)
Take a look at the images below:
I am using Windows 10 64 bits but it happens the same problem with Windows 7, in both 32 and 64 bits versions.
Has anyone had this problem before ?
Dr Claudio Soto can you help ?
Salamandra, Brazil
jorge_riv
DBs Used: DBF, MySQL,SQL SERVER, Oracle.
Re: Strange behavior of HMG IDE
Post by jorge_riv »
Manda las lineas donde te da error, una parte asi lo vemos, yo tenia el mismo problema y lo solucione, pero manda alunas lineas. Gracias
salamandra
Hi @jorge_riv,
jorge_riv wrote: Mon Aug 31, 2020 11:12 pm Manda las lineas donde te da error, una parte asi lo vemos, yo tenia el mismo problema y lo solucione, pero manda alunas lineas. Gracias
There is not problem in my code.
These errors happens after a few builds with HMG IDE Unicode. So, I restart IDE and all runs fine
It seem to be a (perhaps) problem related to not discarded memory
Salamandra, Brazil
Ok, thanks.
As soon as I have time I will add a timer by calling the garbage collector.
salamandra
:) Hi Dr Claudio,
srvet_claudio wrote: Tue Sep 01, 2020 1:21 am Ok, thanks.
Thank you very much !!
Salamandra, Brazil.
please replace old Unicode IDE for this version and test it.
IDE_UNICODE.rar
(1.44 MiB) Downloaded 139 times
salamandra
Hi Dr Claudio,
srvet_claudio wrote: Tue Sep 01, 2020 5:37 pm Hi,
:D Thank you !!
I´ll test it today.
Salamandra, brazil
jairpinho
Post by jairpinho »
hello Dr Claudio, how did you manage to modify the IDE if Mr. Roberto Lopez did not make the source code available, as I have already requested and commented many times here on the forum and we did not aim for success, the growth of HMG depends a lot on the IDE we are running out of resources in the IDE , many people could help without having to start from scratch to build an IDE with new features.
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Hi Jair,
I understand the request to make the source code public, but it does not depend on me, it is Roberto decision.
Mario Mansilla
Post by Mario Mansilla »
Hola Claudio :
un error similar al que menciona nuestro compañero realiza la versión ANSI después de realizar varios formularios . Se van borrando algunos iconos o bien desaparece el listado de propiedades y eventos de los controles hasta que se cierra mostrando errores como si fuera provocado por recursividad .
Mario Rafael Mansilla
