Post
by AUGE_OHR »
i do load a big SDF into EDITBOX using
it does work but when exit and try another big SDF (> 220000 lines) it crash
Question : is there a Way to "free Memory" which was just before
Post
by Rathinagiri »
Have you tried releasing the control and redefine it?
Post
by AUGE_OHR »
i have close Windows and open it again.
happens on 32 Bit OS
salamandra
- DBs Used: DBF, MySQL, SQL
Post
by salamandra »
AUGE_OHR wrote: ↑Mon Aug 03, 2020 6:14 pm
Did you try RELEASE MEMORY ??
Salamandra, Brazil.
Post
by AUGE_OHR »
salamandra wrote: ↑Tue Aug 04, 2020 5:53 pm
no ... but i will try it, THX
salamandra
Post
by salamandra »
AUGE_OHR wrote: ↑Tue Aug 04, 2020 5:58 pm
AFAIK this error means that used memory can´t be discarded.
Perhaps you can use a
Timer Control in your form to execute a
RELEASE MEMORY.
best regards,
Salamandra, Brazil
Carlos Britos
Post
by Carlos Britos »
What about the bytes settled to editbox control ?
AUGE_OHR wrote: ↑Mon Aug 03, 2020 4:06 am
Post
by AUGE_OHR »
Carlos Britos wrote: ↑Tue Aug 04, 2020 8:50 pm
now i direct assign it to EDITBOX VALUE ... hm ...
ok, i will try to write a "RELEASE" function and assign NIL
Post
by AUGE_OHR »
YES, that seems to work now, THX
PROCEDURE TXT_Edit( cFile, lEdit )
LOCAL cMemo := HB_MEMOREAD( cFile )
DEFINE WINDOW TXTEdit ;
ON RELEASE TXTRelease() ;
DEFINE EDITBOX TXTCtrl
VALUE cMemo
END EDITBOX
ACTIVATE WINDOW TXTEdit
cMemo := " "
STATIC PROCEDURE TXTRelease()
TXTEdit.TXTCtrl.Value := " "
