Otis, database tool, new version V1.1 b03, 01-08-2020
Posted: Fri Jul 31, 2020 9:00 pm
Hi everybody,
you can find a new release (v1.1 b03, 01-08-2020) on github :
https://github.com/hansmarc/Otis
Hans
Changelog file : OTIS, Open Table InSpector
Author : Hans Marc (Belgium)
Latest update : 01-08-2020
01-08-2020 : OTIS V1.10 b03
Bug : You get multiple runtime errors if you run Otis.exe from a different location
if you right clicked, by example, on a table file to 'open' it.
Reason, Otis used getcurrentfolder() for the location of the ini file.
We now use hb_dirbase().
Suggestion proposed by Mario (mhsabado).
New : Connexion info LetoDbf rdd
Added server mode info with LETO_GETSERVERMODE()
New : Otis as default windows program to open tables in explorer.
Default rdd driver is always DBXCDX.
New : Command line option :
Otis table1.dbf, table2.dbf, table3.dbf, ...etc.
or
Otis table1.dbf table2.dbf table3.dbf ...etc
will add all the specified tables to a new dataset.
Modif : 'LetoDbf server'
Click 'Add table' with LetoDbf rdd activated.
Some letoDbf servers return a 'Undefined' variable with the leto_directory() function.
We still are searching for the reason.
It happens when we scan the 'root' directory to build a tree for the filepicker form.
code : aDir := leto_directory("\*.*", "D")
if valtype(aDir) == "U"
Otis displays a message if this happens and longer quits with a error.
No subdirectories will be displayed in the "tree" control.
If you see this message please tell me what your server configuration is.
Hans
or
