ADORDD
ADORDD
under c:\hmg.3.4.4\HARBOUR\addons\rddado\ i found ADORDD Source
Question : is it still valid :?:
does someone have try ADORDD with *.XLSx :?:
Re: ADORDD
In C:\Harbour\extras\rddado , adordd.prg, STATIC FUNCTION ADO_OPEN( nWA, aOpenInfo ), line 292
  CASE Lower( Right( aOpenInfo[ UR_OI_NAME ], 4 ) ) == ".xls"
         aWAData[ WA_CONNECTION ]:Open( "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + aOpenInfo[ UR_OI_NAME ] + ";Extended Properties='Excel 8.0;HDR=YES';Persist Security Info=False" )
connection with .xls files is generated, a syntax addition would be needed to see if it is likely to use this extra harbour library
Re: ADORDD
i saw that file but before use it i want to ask if it is still valid ... not like PGRDD :roll:
now Demo use existing Data but i try to create a XLSx and write Data from DBF using ADO.
i try CREATE TABLE but this seem not to work with Excel :(
Re: ADORDD
i found out i need to create a Table in Catalog before fill it.
   oConnect := CreateObject( "ADODB.Connection" )
   oCatalog := CreateObject( "ADOX.Catalog" )
   oTable   := CreateObject( "ADOX.Table" )
   FOR ii := 1 TO iMax
      cField := aStructure[ ii ] [ DBS_NAME ]
      cType  := aStructure[ ii ] [ DBS_TYPE ]
      oColumn  := CreateObject( "ADOX.Column")
      oColumn:Name := cField
      DO CASE
         CASE cType = "C" ; oColumn:Type := adVarWChar
         CASE cType = "M" ; oColumn:Type := adLongVarWChar
         CASE cType = "N" ; oColumn:Type := adDouble
         CASE cType = "D" ; oColumn:Type := adDate
         CASE cType = "L" ; oColumn:Type := adBoolean
      ENDCASE
      oTable:Columns:Append(oColumn)
   oCatalog:Tables:Append(oTable)
than i try use INSERT INTO and i got a *.XLSx which Excel can open :)
CREXLSX.ZIP
(1.45 KiB) Downloaded 134 times
but i can´t open same *.XLSx with ADO again ...
so something still not working :(
Re: ADORDD
i have try ADO Recordset instead of INSERT INTO
   objRS := CreateObject( "ADODB.Recordset" )
   objRS:Open( "Select * from [Sheet$]", oConnect, adOpenKeyset, adLockOptimistic )
   DO WHILE !EOF()
      aField := {}
      aValue := {}
      ii := 1
      FOR ii := 1 TO iMax
         nPosi  := FIELDPOS( cField )
         xValue := FIELDGET( nPosi )
         AADD(aField,cField)
         AADD(aValue,xValue)
      objRS:AddNew(aField,aValue)
      objRS:Update()
      SKIP
   ENDDO
   objRS:Close()
   objRS := NIL
XLSx is create and Excel can open it ... but same when i try to read it with ADO :evil:
while both seems to work i guess Problem is before ... how to create Table ... hm
who have a Idea :idea:
p.s. it work also with 64 Bit
Re: ADORDD
got it :D
instead of
      cSql := "INSERT INTO [Sheet1$] "+ cSelect + "VALUES ( "
use
      cSql := "INSERT INTO [Sheet1] "+ cSelect + "VALUES ( "
it was the "$" which was wrong ( have use it when read XLSx )
Re: ADORDD
here working Sample
CREXLSX2.ZIP
(11.85 KiB) Downloaded 157 times
Source include both Version : INSERT INTO or Recordset
Recordset work with "Update", not with "UpdateBatch" yet
INSERT INTO have Problem with DATE Format
   xValue := DTOC( xValue )
   xValue := DTOS( xValue ) + "000000"
   xValue := HB_STOT( DTOS( xValue ) + "000000" )
none of them seems to work. :(
if someone find right Syntax please post it
Re: ADORDD
Hi Jimmy
Error while I check your code
missing, but unknown function(s): SP_ADBFSTRUCT(),
ONDUMMY(), SETCURSORWAIT(), CALCPOS()
Re: ADORDD
bpd2000 wrote: Sat Aug 01, 2020 5:22 am Error while I check your code
SP_ADBFSTRUCT() -> DBFSTRUCT()
ONDUMMY() is only for debug, delete it
PROCEDURE SetCursorWait( cForm, lOn )
LOCAL nHwnd
   DEFAULT lOn TO .F.
   nHwnd := GetformHandle( cForm )
   IF lOn = .T.
      SetWindowCursor( nHwnd, IDC_WAIT )
      SetWindowCursor( nHwnd, IDC_ARROW )
FUNCTION CalcPos( nValue, iMax )
LOCAL nRet   := 0
LOCAL nEvery
LOCAL xScale
   IF iMax < 100
      nEvery := 100 / iMax
      nRet := nValue * nEvery
      nEvery := INT( iMax / 100 )
      xScale := iMax * nEvery                                         // Scale to 100%
      nRet := iMax / xScale * nValue
RETURN ROUND( nRet, 0 )
Re: ADORDD
Hi
Excel stores dates as sequential serial numbers so that they can be used in calculations. By default, January 1, 1900 is serial number 1, and January 1, 2008 is serial number 39448 because it is 39,447 days after January 1, 1900.
So convert date to serial and store to excel
check code :
Function main()
   SET DATE BRITI
   SET CENT ON
msginfo( serial2dt(39448),"Date serial 44180 to date"+space(10))
msginfo( dt2serial(date()),"Today's Date Serial"+space(10))
return
Function serial2dt(xdt)
   Local x_dateorigin, x_datenew
   SET DATE BRITI
   SET CENT ON
   x_dateorigin := ctod("01/01/1900")
   x_datenew :=( x_dateorigin + xdt ) - 2
Return dtoc( x_datenew )
Function dt2serial(xdt)
   SET DATE BRITI
   SET CENT ON
   x_datenew := (    xdt -x_dateorigin ) + 2
Return  x_datenew
