Hello friends,
I have a queer need,...is there anyway i can force msgInfo() to close a waitWindow()?
Wait Window & MsgInfo()
- karweru
- DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Kind regards,
Gilbert.
Gilbert.
Re: Wait Window & MsgInfo()
To be honest I don't understand what the problem is.
If you want to close WAIT WINDOW before MsgInfo() appears:
and if you want to close after confirming MsgInfo():
WaitWindow()
MsgInfo ("Some info")
WaitWindow()
- karweru
Thanks Edk,edk wrote: ↑Fri Jul 03, 2020 1:49 pm To be honest I don't understand what the problem is.
If you want to close WAIT WINDOW before MsgInfo() appears:and if you want to close after confirming MsgInfo():Code: Select all
(...) WaitWindow() MsgInfo ("Some info") (...)
(...) MsgInfo ("Some info") WaitWindow() (...)
I'm actually looking for a way to AUTOMATICALLY hide/close the WaitWindow() if a program issues a msginfo(). I have a lot of code as follows;
WaitWindow("processing.....")
if error()
msgInfo(<errorMsg>")
return .f.
Of course i can issue a waitWindow() after the msgInfo(),...was just wondering if msgInfo() could automatically issue the waitWindow()....more of being lazy
Kind regards,
Gilbert.
Gilbert.
- mustafa
Hi karweru
Could inkey () work?
FUNCTION MAIN
DEFINE WINDOW MAINx AT 0, 0 WIDTH 800 HEIGHT 600 TITLE ""ICON '' Main NOSIZE NOMINIMIZE NOMAXIMIZE ON INIT Export()
ON KEY ESCAPE ACTION Mainx.Release
DEFINE BUTTON Button_1
ROW 440
COL 370
WIDTH 110
HEIGHT 040
ACTION Export()
CAPTION "Wait"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .T.
FONTITALIC .F.
END BUTTON
Mainx.Center
Mainx.Activate
Function Export()
SetProperty("_HMG_CHILDWAITWINDOW","Width ", 450)
SetProperty("_HMG_CHILDWAITWINDOW","Height", 130)
SetProperty("_HMG_CHILDWAITWINDOW","Message","Width" ,450)
SetProperty("_HMG_CHILDWAITWINDOW","Message","Height",130 )
SetProperty("_HMG_CHILDWAITWINDOW","Message","Row",2)
SetProperty("_HMG_CHILDWAITWINDOW","Message","COL",2)
SetProperty("_HMG_CHILDWAITWINDOW","Message","FontColor", {128,000,000})
SetProperty("_HMG_CHILDWAITWINDOW","Message","BACKCOLOR", {198,245,183})
SetProperty("_HMG_CHILDWAITWINDOW","Message","FONTNAME" ,"Times New Roman") // <--- "Arial"
SetProperty("_HMG_CHILDWAITWINDOW","Message","FONTSIZE" , 16 )
SetProperty("_HMG_CHILDWAITWINDOW","Message","FONTBOLD" ,.T.)
SetProperty("_HMG_CHILDWAITWINDOW","Message","FONTITALIC",.T.)
wait window CRLF +'Processing Table - »' + CRLF+ 'stock.db3' nowait
inkey(3)
wait clear
