Row Refresh in a BROWSE
Re: Row Refresh in a BROWSE
Hi Gabor,
SUCCESS! Thank you so much for sharing your HMG expertise. Your solution works great. I can live with the browse "flickering".
Again, thanks for your help. It is really appreciated!
Red2
Red2
- AUGE_OHR
still flicker so try this
you are right
DoMethod(cBroMacro, "BrowserView","Refresh",.T.)
RefreshCurrent(cBroMacro, "BrowserView")
PROCEDURE RefreshCurrent(cForm,cBrowse)
LOCAL hBrowse := GetControlHandle(cBrowse, cForm )
LOCAL nRecord := GetProperty( cForm, cBrowse, "VALUE" )
ListView_RedrawItems( hBrowse, nRecord, nRecord )
It's not working with BROWSE in my opinion
Hi Jimmy,
Thank you for your reply and suggestion. I added your code. My form's name is "DataBrowse" and the BROWSE's name is "BrowseStates".
Unfortunately it produced no refresh at all. (Perhaps my calling parameters are not correct):
It would be very nice if HMG could refresh only the BROWSE's altered record.
If you have any further suggestions I would really appreciate hearing them.
Red2
RefreshCurrent( "DataBrowse", "BrowseStates" )
Red2
Hi Jimmy,
Thank you for your quick reply, I really appreciate it! Am I understanding your question correctly? I:
1) Replace the field value
2) Set flag llRefresh
3) Then, if TRUE, call function RefreshCurrent()
My code follows:
QUESTION: What am I missing here?
Thanks again,
Red2
My code follows:
function ToPrintToggle( p_lPrint)
select "By_State"
local llRefresh := .F.
if ( p_lPrint ) // TRUE
if ( upper( By_State->MergeState ) != "Y" )
replace By_State->MergeState with "Y" // <--- REPLACEMENT
llRefresh := .T.
else // FALSE
if ( By_State->MergeState != " " )
replace By_State->MergeState with " " // <--- REPLACEMENT
llRefresh := .T.
if ( llRefresh )
return Nil
Thanks again,
Red2
- AUGE_OHR
i use DBF with virtual GRID which display faster while it must not read DBF -> Array -> Refresh
so here Code for Array or DBF using GRID or BROWSE
your are right, Code was for GRID and does not refresh with BROWSE
ACTIVATE WINDOW &oBroEdit
DoFindWin( cDBF )
#IFDEF Use_DataBrowse
Refreshline(cBroMacro,"BrowserView",aStruc)
#ELSE
#ENDIF
STATIC PROCEDURE Refreshline(cForm,cBrowse,aStruc)
LOCAL ii, iMax := LEN(aStruc)
LOCAL nRow := GetProperty( cForm,cBrowse,"VALUE")
LOCAL cField,nPosi,xValue
FOR ii := 1 TO iMax
cField := aStruc[ ii ] [ DBS_NAME ]
nPosi := FIELDPOS( cField )
xValue := FIELDGET(nPosi)
SetProperty( cForm, cBrowse, "CELL", nRow, ii, xValue )
STATIC PROCEDURE RefreshCurrent(cForm,cBrowse)
Hi Jimmy!
Your sample for BROWSE control is not correct.
"VALUE" property of BROWSE return record number in database, not row numer of BROWSE.
So, it can work only if your database is not indexed and you don't have deleted rows or you use SET DELETED OFF.
I don't know property which shows line number of browse.
An interesting observation: In HMG-Extended when I execute
I detect zero REFRESH "flickering" in my BROWSE.
At this moment I am still using "Harbour MiniGUI Extended Edition 20.05 (Update 2)".
Nevertheless it would still be nice if there was a HMG "flickering" solution.
Red2
DoMethod( "DataBrowse", "BrowseStates", "Refresh" )
Red2
Mol, I use for grid line number
formname.gridname.recno for grid record
formname.gridname.recno() for table record
not sure if it works for browse.
All The Best,
Franco
Canada
Franco
Canada
