Post
by AUGE_OHR »
i found Sample c:\MiniGUI\SAMPLES\Advanced\ReadXLS_2\ReadExcel.PRG
it work fine but i have a Problem with "unknown" XLSx how to get 1st Sheet Name
default it is "Sheet1" but if User have use different Name ...
objRS1 := CreateObject( 'ADODB.Recordset' )
strRange := mySheet + '$' // ALL
// strRange := mySheet + "$" + my1stCell + ":" + myLastCell
BEGIN SEQUENCE
objRS1:Open( "Select count(*) from [" + strRange + "]", objExcel, adOpenStatic )
DO WHILE .NOT. objRS1:EOF()
nMaxLen := MAX( nMaxLen, objRS1:Fields( 0 ) :Value() )
objRS1:MoveNext()
ENDDO
objRS1:Close()
RECOVER USING oError
ERRORBLOCK( bError )
MsgStop( "Operation: " + oError:Operation + " - Description: " + oError:Description, "Error" )
END SEQUENCE
using ActiveX i can "Set" Sheet Name using
oExcel:Application:Worksheets(1):name := ID_USER
Post
by bpd2000 »
AUGE_OHR wrote: ↑Sat May 30, 2020 5:54 am
Working Sample attached
//bpd2000 31-05-2020
#ifndef __XHARBOUR__
#xcommand TRY => BEGIN SEQUENCE WITH {|oErr| Break( oErr )}
#xcommand CATCH [<!oErr!>] => RECOVER [USING <oErr>] <-oErr->
#endif
FUNCTION MAIN()
GetExcelsheetname()
Return NIL
//This function reads an Excel sheet name without using MS-Office
Function GetExcelsheetname()
LOCAL objExcel, rsSchema, oError
LOCAL myXlsFile := "Demofile.xls"
objExcel := TOleauto():New('ADODB.Connection')
objExcel:ConnectionString ='Provider=Microsoft.ACE.OLEDB.12.0;' + ;
'Data Source=' + myXlsFile + ';' + ;
'Extended Properties="Excel 12.0 Xml;' + "" +'IMEX=1' + '";'
TRY
objExcel:Open()
CATCH oError
MsgStop("Operation: " + oError:Operation + " - Description: " + oError:Description, "Error")
RETURN arrData
END
rsSchema := objExcel:OpenSchema(20)
rsSchema:MoveFirst()
Do While ! rsSchema:EOF()
msginfo((rsSchema:Fields("table_name"):VALUE))
rsSchema:MoveNext()
enddo
rsSchema:Close()
objExcel:Close()
Return nil
- ExcelSheetName.zip
- (1.45 MiB) Downloaded 165 times
