NC Clone
Re: NC Clone
Gracias Jimmy por compartir / thanks for sharing
Re: NC Clone
attached Version v0.73
HBFM073.zip
(1.81 MiB) Downloaded 202 times
when start v0.73 it will upgrade FMSETUP.DBF and use a new Directory
GETENV( "APPDATA" ) + "\HMG" -> c:\Users\YourName\AppData\Roaming\HMG\FMSETUP.DBF
if upgrade make Problem i have include FMSETUP.ZIP
Note : all my HMG Tools will use that Directory and Settings e.g. Color
fixed :
FMSETUP.DBF Bug when not "upgrade"
new :
System-Icon using BT_DirectoryInfo() ( THX to Dr. Claudio Soto )
add Field USEIMAGE -> Setup -> Checkbox UseImage
Directory for FMSETUP change to GETENV( "APPDATA" ) + "\HMG"
ALT-F7 with "normal" search (and Everything if installed )
OSK.EXE on Toolbar
"Enter" on Toolbar for Touch-Screen
known Problem :
when ShellOpen a File on TAB > 1 Grid will not "refresh"
Combobox "open" with Mouse ( work well with Keyboard)
TAB-Key with TAB > 1 to change focus to other side
only F1-F11, Crtl-T and Crtl-U are working under TAB > 1
Re: NC Clone
Release 0.81
HBFM081.zip
(1.83 MiB) Downloaded 183 times
i add Support for Device like Smartphone or "Digi-CAM" to COPYHERE() files to Target Folder
as it are most Images i add Thumbs-Preview where you can mark/un-Mark Thumbs using SPACE-Bar.
Result will "mark" Files in GRID so you can move/delete them
fixed :
new :
v.0.81 14.04.2020 Progressbar (in Titlebar) while loading Thumbs
v.0.80 13.04.2020 Thumbs-Select-Grid
v.0.79 12.04.2020 Thumbs-Progressbar-Thread
v.0.78 11.04.2020 Phone2.PRG, THUMBS.PRG include
v.0.77 29.03.2020 IPHONE GetDevicePath()
v.0.76 27.03.2020 Slideshow() , SetLV_View()
v.0.75 25.03.2020 ON MOUSEMOVE / ON MOUSEDRAG on wrong Parent
v.0.74 22.03.2020 BT_DirectoryInfo() with Thread. Add MenuItem : Attribut
known Problem :
Re: NC Clone
next Version 0.87
HBFM087.zip
(1.96 MiB) Downloaded 181 times
fixed :
F5 COPY might produce "- Kopie" ( German ) while old File was not override
new :
v.0.87 21.04.2020 ALT-F5 ZIP ( COMPRESS )
v.0.86 18.04.2020 VK_MULTIPLY : reverse selection
v.0.85 17.04.2020 ALT-F7 search in File
v.0.84 15.04.2020 Splash Intro
v.0.83 16.04.2020 DirWatch ( wapi_WaitForSingleObject )
v.0.82 14.04.2020 COPYHERE() or MOVEHERE() limited to Device only
have add MOVEHERE() for Device
DirWatch will "refresh" when something in Folder change
Splash Intro just "hide" App when build on Start
ALT-F7 now can search Text "in" File. F3/F4 and Ctrl-F for search RTF and TXT (PRG)
Numpad * will reverse Selection
ALT-F5 ZIP "simple"
known Problem :
when files was delete by other App refresh might "double" each Item -> Workaround Crtl-R
COPYHERE / MOVEHERE Button might not display, please restart HBFM and try again.
Steed
Re: NC Clone
Post by Steed »
Thanks
Re: NC Clone
lates Version 0.95
HBFM095.zip
(1.97 MiB) Downloaded 180 times
fixed
fixed Thumbs STRZERO(n,3) -> STRZERO(n,5), sort Name
new
v.0.95 17.05.2020 search in ZIP
v.0.94 15.05.2020 NetConnect()
v.0.93 10.05.2020 without FreeImage.DLL but "Cache"
v.0.92 08.05.2020 Thumbs using FREE_Save() 2 x faster than BT function
v.0.91 07.05.2020 Thumbs using FreeImage.DLL
v.0.90 06.05.2020 Thumbs using MouseWheel
v.0.89 04.05.2020 try FreeImage.DLL
v.0.88 25.04.2020 fixed Thumbs STRZERO(n,3) -> STRZERO(n,5), sort Name
Thumbs "Cache" when create. will be delete when change Folder
Net Connect/disConnect Dialog
ALT-F7 search in ZIP
comment :
have try FreeImage which IS twice faster as BT API Function.
but it need 3-PP DLL, else App does not start ...
i also have ready sFTP Transfer but same with "more" DLL ... hm
i want to create a "pure" HMG App
known Problem :
search in ZIP does not work with Everything
Re: NC Clone
latest Version 0.97
HBFM097.zip
(1.96 MiB) Downloaded 191 times
fixed : Dirwatch produce "dupe" in GRID
since v0.83 i have use DirWatch with
      // watch file name changes ( file was CREATED, RENAMED or DELETED)
      pChangeHandle := wapi_FindFirstChangeNotification( cDir, .F., FILE_NOTIFY_CHANGE_FILE_NAME )
now i found out that i have to use
      pChangeHandle := wapi_FindFirstChangeNotification( cDir, .F., FILE_NOTIFY_CHANGE_NAME )
to get rid of "dupe" in GRID
// v.0.97 24.05.2020 working DirWatch ... FILE_NOTIFY_CHANGE_FILE_NAME -> FILE_NOTIFY_CHANGE_NAME
// v.0.96 21.05.2020 Problem with (many) DirWatch and TAB > 1 - aWatchThread
Re: NC Clone
here latest Version 1.03
HBFM103.zip
(2.09 MiB) Downloaded 188 times
// v.1.03 10.06.2020 fix WatchDirLeft() / WatchDirRight() empty Path
// v.1.02 03.06.2020 HbFilter more validation
// v.1.01 02.06.2020 HbFilter
// v.1.00 29.05.2020 INIT PROC before MAIN
// v.0.99 27.05.2020 Export : DBF, XLSx, SDF
// v.0.98 26.05.2020 PickList()
when View / Edit (F3/F4) DBF you get a Picklist for Fields in DBF.
ESC -> all Fields
F5 "Copy" in Browser : Export to Excel need libxlsxwriter.dll.
DLL_Only_xlsxwriter.zip
(328.1 KiB) Downloaded 201 times
F3 now read Excel XLSx Files via ADO and display in GRID ( no Fx Button yet )
HBFM only start once as i have not test it with many Instance
in Browse you can press Crtl-F8 to get "Filter-Assistant"
if you want you can direct write in Editbox and EVAL() it
know Problem :
DirWatch does not recognize Create / Delete Folder
without libxlsxwriter.dll "pure" Version is buggy writing XLSx Files
Darkmode : when GRID does not fill full TAB Background might be not Darkmode
Re: NC Clone
forgot that ADO is not part of Windows 10 ... it is from Office :roll:
but you can get Engine here : AccessDatabaseEngine
https://www.microsoft.com/de-de/downloa ... x?id=13255
this is a German Link and from 2010 but it work with XLSx
there are also newer Version like 2016 here
https://www.microsoft.com/en-us/downloa ... x?id=54920
Re: NC Clone
here 64 Bit Version of HBFM64
HBFM64.zip
(2.4 MiB) Downloaded 186 times
for FreeImage64 it need this DLL
http://www.hmgforum.com/viewtopic.php?f ... 7&start=23
XLSx Files does not work in this 64 Bit Version while i have no libxlsxwriter64.dll :(
