NC Clone
- AUGE_OHR
Re: NC Clone
v0.045
BUG aStart "unmark"
RootUpDirPath()
new:
PathInfo and CMDBox (under Construction)
Crtl-F8 and ALT-F10 both "just" use GetFolder()
all Variable check with -w1 -es2
fixed :BUG aStart "unmark"
RootUpDirPath()
new:
- AUGE_OHR
Re: NC Clone
v0.050
so i have change Setup and add new Field in FMSETUP.DBF (Check will done automatic)
you can enable/disable use of LISTVIEW_SETCOLUMNWIDTH
fixed :
DELETE right side does not update Grid (left side work)
change :
FMSETUP.DBF add Field COLRESIZE "L"
FMSETUP Layout change
add new
Context Menu add sort, tree, sendto
CMDBox working (Del Key blockt ?)
Font Picker
Font-Name is for all, Font-Size is default, Font-Large for GRID / Listbox and Font-Small for Label in FMsetup.
When re-size using LISTVIEW_SETCOLUMNWIDTH it is very slow on some PC.so i have change Setup and add new Field in FMSETUP.DBF (Check will done automatic)
fixed :
change :
add new
Font Picker
- AUGE_OHR
Re: NC Clone
v0.057
you can use F2,F3 to view in every Window and "let it open"
you can use F4,F6,F7,F9 in every Window but it is recommend to close it after using
include SumatraPDF as Viewer ( need SumatraPDF.exe )
new :
F6 : Select Index "sometimes" does not enable F7 "Seek".
close DBF and try again with just 1 x Index. later you can press F6 again and use multi Index/Tag
Tip Scope :
it does support full Syntax
so you can use "K,M" for Scope
this will be last Version with BROWSE as i have some DBF OEM Problem so i switch to GRID in next Version
this Version support multi Windows with BROWSE and Fx-Keyyou can use F2,F3 to view in every Window and "let it open"
new :
know Problemv.0.57 24.02.2020 OEM Problem ... Byte 30 -> "DOS 850" ?
v.0.56 24.02.2020 multi Browser F6 / F7 / F9 und F1 Info
v.0.55 23.02.2020 multi Browser WITHOUT Thread
v.0.54 23.02.2020 Sumatra PDF WITHOUT SET_COMPILE_HMG_UNICODE
v.0.53 22.02.2020 Sumatra PDF
v.0.52 22.02.2020 multi Browser with Thread und Macro
v.0.51 22.02.2020 all transfer from MAIN to FMGrid.PRG
Tip Scope :
SET SCOPE TO [<expNewTop> [, <expNewBottom>]]
- AUGE_OHR
Re: NC Clone
i have change View BROWSE to GRID
i know it was FOUND() and i can check it with F3/F4 ... but GRID does not show it
here is a Difference in "set Position" between BROWSE and GRID
after SEEK() i use VALUE in BROWSE but with GRID i have to use RECNO
the Reason why i change from BROWSE to GRID was "ON QUERYDATA".
when using ROWSOURCE i seem not to work with VIRTUAL ... ON QUERYDATA does not fire Event
so i can not "manipulate" what is display in GRID ... but it is much faster than BROWSE e.g. when resize
now GRID display and i press F6 for Index and F7 for SEEK.1.) change DEFINE BROWSE to DEFINE GRID
2.) change FIELDS aFeld to COLUMNFIELDS aFeld
3.) change WORKAREA &cWorkArea to ROWSOURCE (cWorkArea)
4.) change END BROWSE to END GRID
nRec := RECNO()
#IFDEF Use_Browse
SetProperty( oBrowse, "BrowserView", "Value", nRec )
#ELSE
SetProperty( oBrowse, "BrowserView", "RecNo", nRec )
#ENDIF
- AUGE_OHR
Re: NC Clone
Problem with close TAB
guess build 3 x TAB with GRID
have fix it for next Release.
now close TAB 2Grid_1
Grid_2
Grid_3
add new TABGrid_1
Grid_3
so until now it is need to close LAST TAB ... that is not what i wantGrid_3 Of WinLeft Already defined.
- AUGE_OHR
Re: NC Clone
v0.064 fixed :
close TAB
new:
BROWSE -> GRID
F9 History : Last visit Folder
HBINPUT own InputBox()
DBF Viewer F10 Codepage
Grid with Image
please have a look at Thread about Codepage
http://hmgforum.com/viewtopic.php?f=5&t=6350
v0.064 fixed :
close TAB
new:
BROWSE -> GRID
Grid with Image
- AUGE_OHR
Re: NC Clone
here latest Version 0.68 fixed :
Browser : F9 wrong Position when maximize
new :
*.LNK -> DXE_ResolveLink()
save / restore multi TAB (Array in Memo)
use Parameter /L /R to load TAB Directory. use # as Delimiter
! Note : when using /L /R those TAB setting are not write to FMSETUP.DBF
p.s. FMSETUP.DBF will be automatic modify by this Update to store Array in Memo
new :
HBFM.exe /Le:\TEMP\#c:\hmg.3.4.4\0\HBFM\ /Rd:\ALASKA\SHFILE\#c:\hmg.3.4.4\0\USB\#f:\CT\
Re: NC Clone
Hello AUGE_OHR,
Start running this program, show the following error to stop running!
Date:03/13/2020 Time: 21:11:14
Error BASE/1111 Argument error LEN Parameter : [ 1] = U NIL
Called from LEN(0)
Called from TESTSTORETAB(4725)
Called from FILLGRID(990)
Called from (b)DUALGRID(305)
Called from _PROCESSINITPROCEDURE(5858)
Called from _ACTIVATEWINDOW(5609)
Called from DUALGRID(849)
Called from MAIN(142)
Called from LEN(0)
- AUGE_OHR
Re: NC Clone
was it a "fresh install" or upgrade from older Version
please use this DBF with this Version when "fresh" install
arrrrrrrrrrggggggghuiyi_ch wrote: ↑Fri Mar 13, 2020 1:19 pm Hello AUGE_OHR,
Called from LEN(0)
- AUGE_OHR
Re: NC Clone
i have found "HMG Easy Build" from Dr. Claudio Soto, GREAT WORK
http://www.hmgforum.com/viewtopic.php?f ... 903#p36229
i saw "System-Icon"
and i found out how BT_DirectoryInfo() work only Problem : it take some time ...
i will open a new Thread how to make it faster
i saw "System-Icon"
