HMG-specific GRID syntax help needed
Red2
Re: HMG-specific GRID syntax help needed
Post by Red2 »
Thank you for you suggestions. Unfortunately there is still a (blank) grid display issue of some kind.
To recap:
1) The grid’s code in the .FMG is now more simplified (see below).
2) Verified: The .DBF is opened prior to “ACTIVATE WINDOW ” with GOTO TOP.
3) Verified: The .DBF is the work area’s current alias according to:
----Debugger
----Vertical (row) grid navigation occurs.
----Row navigation perfectly reflects the RECCOUNT().
----The ALIAS() is displayed by textbox “Text_1”
4) Page “Page 1” is NOT readonly because textbox “Text_1” displays the alias.
5) The HMG help file lists two grid control syntaxes, “Standard Syntax (xBase Style)” and “Alternate Syntax”. I am using “Alternate Syntax” with no semicolons at line’s end.
    DEFINE TAB pgf_ItemsStates AT 40 , 30 WIDTH 820 HEIGHT 430 VALUE 1 FONT "Arial" SIZE 9 TOOLTIP "" ON CHANGE Nil MULTILINE
        PAGE "Page 1"
            DEFINE GRID grd_Items
                ROW     50
                COL     40
                WIDTH   740
                HEIGHT  300
                VALUE   1
                WIDTHS  { 150, 150 }
                HEADERS { "Mfg. Name", "Type" }
                ROWSOURCE "All_Items"
                COLUMNFIELDS {"All_Items->MFG_NAME", "All_Items->TYPE"}
            END GRID
            DEFINE TEXTBOX Text_1
                ROW    370
                COL    50
                WIDTH  230
                HEIGHT 25
                FONTNAME "Arial"
                VALUE  "Value:  " +chr(34)+alias()+chr(34)+ "  (is the ALIAS)"
            END TEXTBOX
        END PAGE
        PAGE "Page 2"
        END PAGE
    END TAB
I am STUCK and a bit frustrated! What am I missing? There must be something obvious being overlooked!
I am really grateful for all of your kind help. Once again, any further ideas would most appreciated.
Red2
next try : you 1st Line seems different to my
seems you work on TAB Page not on WINDOW ...
DEFINE WINDOW TEMPLATE AT 371 , 616 WIDTH 466 HEIGHT 561 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL  CURSOR NIL ON INIT OpenDbfReply() ON RELEASE CloseDbfReply() ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR {0,0,0} NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
i'm still a harbour / HMG Newbie but as i understand FMG is a TEMPLATE which is missing in your Code
i have look for VALUE in my Code and it was NIL at Start
try a small Demo with WINDOW if it work, than you can try TAB again.
hope it help
Red2
Post by Red2 »
Thank you Jimmy,
I really appreciate your help. As for the pages (code) in my last post, it is not really relevant to the issue. That is, whether the grid is on a page or not, the grid does not display the .DBF's records. In both cases grid rows are all blank/empty.
In my last post I did not include my "DEFINE WINDOW" code but it is actually there in my .FMG. It was generated by the IDE and is not interesting (unless I am missing something).
DEFINE WINDOW TEMPLATE AT 151 , 313 WIDTH 891 HEIGHT 593 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "View/Edit Data" ICON NIL MODAL NOSIZE CURSOR NIL ON INIT ItemsBrowse_Frm_OnInit() ON RELEASE ItemsBrowse_Frm_OnRelease() ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON PAINT Nil BACKCOLOR Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
...  // (See my previous post's code)
I should mention that both "ItemsBrowse_Frm_OnInit()" and " ItemsBrowse_Frm_OnRelease()" are just empty stubs for now.
Still stuck but I am sure someone can explain my error or omission! Thanks again everyone for your most generous help.
Red2
Red2 wrote: Tue Dec 10, 2019 12:21 am I should mention that both "ItemsBrowse_Frm_OnInit()" and " ItemsBrowse_Frm_OnRelease()" are just empty stubs for now.
hm ... perhaps is "that" the Problem :?:
yes, i know you have check it but you can re-open it just before load FMG
PROCEDURE Choise_TO()
   IF !IsWindowDefined( ReplayTo )
      IF OpenDbfReply()
         cTOwho  := "TO"
         Load Window ReplayTo
         ON KEY ESCAPE OF ReplayTo ACTION ReplayTo.Release
         ON KEY RETURN OF ReplayTo ACTION Save_To()
         ON KEY DELETE OF ReplayTo ACTION DelReplay()
         CENTER WINDOW ReplayTo
         Activate Window ReplayTo
         CloseDbfReply()
         MsgInfo("Error open REPLYTO.DBF")
FUNCTION OpenDbfReply()
LOCAL lRet := .T.
   SELECT 3
   USE REPLYTO.DBF ALIAS REPLYTO EXCLUSIVE
   IF NETERR()
      lRet := .F.
      SET INDEX TO REPLYTO.CDX
RETURN lRet
PROCEDURE CloseDbfReply()
   SELECT 3
   CLOSE
   SELECT 1
Parecerá tontería, pero ya checaste que los colores que estas usando no son WHITE / WHITE ?
It will seem silly, but have you checked that the colors you are using are not WHITE / WHITE ?
Sin ver tu ejemplo funcional, es estar adivinando...
Without seeing your functional example, it's being guessing ...
Red2
Post by Red2 »
Thank you Jimmy and Andyglezl. I really appreciate all of your kind help!
1) The button that calls the .FMG (with the grid) selects the .DBF immediately before calling the form. (Please see code below).
----The work area should be correctly set, no?
----Based on the grid’s navigation accurately reflecting the RECCOUNT() I do not see how the RowSource is set wrong.
declare window ItemsBrowse
function main_Btn_ItemsBrowse_Action()
	select "All_Items"
	goto top
	if ( isWindowActive( ItemsBrowse ) )
            doMethod( "ItemsBrowse", "Minimize" )
            doMethod( "ItemsBrowse", "Restore" )
            doMethod( "ItemsBrowse", "SetFocus" )
            load window ItemsBrowse
            ItemsBrowse.Center
            ItemsBrowse.Activate
2) It is not silly to question the grid’s FontColor. I changed the grid's FontColor from Nil (the default) to {0,0,0). The grid still displays rows blank/empty. I believe we can rule out FontColor.
What am I overlooking???
Thanks again,
Red2
ROBROS
Post by ROBROS »
Hi Red,
in your code should be defined 1 (one) main window.
In your code you define a "main function", but there is no "main window" within "function main"
Robert
Red2
Post by Red2 »
Interesting Fact:
If I simply substitute "my" grid for the "sample" grid in "P:\HMG.3.4.4\SAMPLES\Basics\TUTORIAL\Tutor20.PRG" my .DBF data displays perfectly!
This tells me that "my" grid is not the problem. Something else is certainly the cause!
In my program the cause is not the "tab pages" because my grid still is blank when the pages are remove and (the grid) is placed directly onto the form.
QUESTION: Can those of you more experienced in HMG/Harbour explain what "blanks" a grid??? I am very baffled!
Thank you,
Red2
Here I just open "my" .DBF. and increase the size of the window to hold "my" grid. My .DBF has 8 type character fields.
// P:\HMG.3.4.4\SAMPLES\Basics\TUTORIAL\Tutor20.PRG
//	I simply substitute my grid and .DBF
OpenTables()
DEFINE WINDOW Win_1 ;
	WIDTH 1000 HEIGHT 500 ;
	TITLE 'Tutor 20: GRID Test' ;
	MAIN NOMAXIMIZE
	DEFINE MAIN MENU
		POPUP 'File'
			ITEM 'Set Grid RecNo' ACTION Win_1.Grid_1.Value := Val ( InputBox ('Set Grid RecNo','') )
			ITEM 'Get Grid RecNo' ACTION MsgInfo ( Str ( Win_1.Grid_1.RecNo ) )
			SEPARATOR
			ITEM 'Exit' ACTION Win_1.Release
		END POPUP
		POPUP 'Help'
			ITEM 'About' ACTION MsgInfo ("Tutor 20: GRID Test")
		END POPUP
	END MENU
//         @ 10,10 GRID Grid_1 ;
//            WIDTH 610 ;
//            HEIGHT 390 ;
//            HEADERS { 'Code' , 'First Name' , 'Last Name', 'Birth Date', 'Married' , 'Biography' } ;
//            WIDTHS { 150 , 150 , 150 , 150 , 150 , 150 } ;
//            ROWSOURCE "Test" ;
//            COLUMNFIELDS { 'Code' , 'First' , 'Last' , 'Birth' , 'Married' , 'Bio' } ;
//            COLUMNCONTROLS {{'TEXTBOX','NUMERIC','999'},{'TEXTBOX','CHARACTER'},{'TEXTBOX','CHARACTER'},{'TEXTBOX','DATE'},{'CHECKBOX'},{'TEXTBOX','CHARACTER'}};
//            ALLOWDELETE ;
//            EDIT
    DEFINE GRID Grid_1  // My grd_Items is renamed here to: Grid_1
	ROW    10
	COL    20
	WIDTH  950
	HEIGHT 400
	VALUE 1
	WIDTHS   { 150, 150, 90, 100, 150, 100, 100, 150 }
	HEADERS  {"Mfg. Name", "Type", "Serviceable", "Descr.", "Model", "Length", "OAL", "Serial Nbr"}
	FONTNAME "Arial"
	FONTSIZE 9
	TOOLTIP ""
	ONCHANGE Nil
	ONGOTFOCUS Nil
	ONLOSTFOCUS Nil
	FONTBOLD .F.
	FONTITALIC .F.
	FONTUNDERLINE .F.
	FONTSTRIKEOUT .F.
	ONDBLCLICK Nil
	ONHEADCLICK Nil
	ONQUERYDATA Nil
	MULTISELECT .F.
	ALLOWEDIT .F.
	VIRTUAL .F.
	DYNAMICBACKCOLOR Nil
	DYNAMICFORECOLOR Nil
	COLUMNWHEN Nil
	COLUMNVALID Nil
	COLUMNCONTROLS Nil
	SHOWHEADERS .T.
	CELLNAVIGATION .F.
	NOLINES .F.
	HELPID Nil
	IMAGE Nil
	JUSTIFY Nil
	ITEMCOUNT Nil
	BACKCOLOR NIL
	FONTCOLOR {0,0,0}
	HEADERIMAGES Nil
	COLUMNFIELDS  {"MFG_NAME", "TYPE", "SERVICEABL", "DESCR", "MODEL", "LENGTH", "OAL", "SERIAL_NBR"}
	ALLOWAPPEND .F.
	ALLOWDELETE .F.
	BUFFERED .F.
	DYNAMICDISPLAY .F.
	ONSAVE Nil
	LOCKCOLUMNS 0
    END GRID
CENTER WINDOW Win_1
ACTIVATE WINDOW Win_1
Procedure OpenTables()
	REQUEST DBFCDX, DBFFPT
	RDDSETDEFAULT ("DBFCDX")
	USE ( "P:\HMG\All_Items.DBF" ) exclusive NEW
	set index to "P:\HMG\All_Items.CDX"
	set order to 1
	goto top
ROBROS
Post by ROBROS »
Hi Red,
I send you a simple grid example, I left out the properties I do not need. See attached zip-file. Maybe it helps you.
Robert
GRID.7z
(1.21 MiB) Downloaded 137 times
Red2 wrote: Tue Dec 10, 2019 7:25 pm Here I just open "my" .DBF. and increase the size of the window to hold "my" grid. My .DBF has 8 type character fields.
//            WIDTH 610 ;
//            HEIGHT 390 ;
//            ALLOWDELETE ;
//            EDIT
what is with that Code :?: does it not work :o
try again and strip
   ALLOWDELETE ;
   EDIT
strip all to minimum
	ROW    10
	COL    20
	WIDTH  950
	HEIGHT 400
    END GRID
if it work you can add "more"
while i had Problem with GRID and
i have try BROWSE ( NOT Browse() ) which is also a WC_LISTVIEW ( = GRID )
BROWSE have
        WIDTHS {200,200}
        HEADERS {"Reply To","From"}
        WORKAREA REPLYTO
        FIELDS {"REPLYTO->REPLYTO" , "REPLYTO->FROM"}
benefit of BROWSE : it have
   SET BROWSESYNC ON
what does it mean :
when load data from DBF into GRID it will IHMO not move Pointer in DBF when navigate in GRID.
when look into c:\hmg.3.4.4\SOURCE\h_browse.prg and search for "BROWSESYNC" you will find this
Procedure _BrowseSync (i)
Local _Alias
Local _BrowseArea
Local _RecNo
Local _CurrentValue
	If _HMG_SYSDATA [ 254 ] == .T.
		_Alias := Alias()
		_BrowseArea := _HMG_SYSDATA [ 22 ] [i]
		If Select (_BrowseArea) == 0
		EndIf
		Select &_BrowseArea
		_RecNo := RecNo()
                _CurrentValue := _BrowseGetValue ( '' , '' , i )
		If _RecNo != _CurrentValue
			Go _CurrentValue
		EndIf
		if Select( _Alias ) != 0
			Select &_Alias
		Else
			Select 0
		Endif
	EndIf
i do not found something like this in GRID so for DBF i "think" BROWSE is better Way with "SET BROWSESYNC ON" :idea:
