Recieve a Json string created by website
zolysoftsolutions
Post by zolysoftsolutions »
Hi my friends,
On a website named www.zolano.ro it happens something, saved into a json string.
I can transfer this data by calling from another website trough this code in php:
$curl = curl_init();
curl_setopt($curl, CURLOPT_CUSTOMREQUEST, "POST");
curl_setopt($curl, CURLOPT_POSTFIELDS, $data);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, true);
curl_setopt($curl, CURLOPT_HTTPHEADER, array(
    'Content-Type: application/json',
    'Content-Length: ' . strlen($data))
curl_setopt($curl, CURLOPT_URL, 'http://www.zolano.ro/');  // The url path we want to call
$result = curl_exec($curl);
//see the results
$valami=json_decode($result,true);
curl_close($curl);
foreach ($valami as $xxx) {        //is arrays in array ...so is a table content with 3 columns
  foreach ($xxx as $yyy) {
   print_r($yyy[0]); echo "  ";
   print_r($yyy[1]); echo "  ";
   print_r($yyy[2]); echo "<br>";
My question is if I can do this also in a HMG application installed on a pc connected to internet?
I have to mention that I checked the sample of master Rathinagiri, but there I have to call/recieve the string, not just to read from a file with .json extension.
Normally I can save the json string into a file in this way ...
$fp = fopen('results.json', 'w');
fwrite($fp, json_encode($result,true));
fclose($fp);
..and to download in HMG app trough FTP. Exist a simpler way?
Zoli B.
_______________________________
Open eyes for you!
Re: Recieve a Json string created by website
Function Main()
Local cURL := "http://www.zolano.ro/"
Local cPOSTdata
LOCAL cResp, hRest, oWeb
//Init
BEGIN SEQUENCE WITH {|o| break(o)}
	oWeb := Win_OleCreateObject( "MSXML2.ServerXMLHTTP" )
RECOVER
     MsgStop( "Microsoft XML Core Services (MSXML) 6.0 is not installed."+CRLF+;
          "Download and install MSXML 6.0 from http://msdn.microsoft.com/xml"+CRLF+;
          "before continuing.")
     oWeb:=""
END SEQUENCE
IF EMPTY(oWeb)
	MsgStop("Error while init.")
cResp := SendRequest( cUrl, cPOSTdata, oWeb )
IF cResp = "!ERROR!"
	MsgStop( cResp )	/* Report any errors */
	hResp := hb_jsonDecode( cResp )
	MsgDebug( cResp )
	MsgDebug( hResp )
//Close
oWeb:Abort()
Function SendRequest (cUrl, cPOSTdata, oWeb)
Local cReturn
Default cPOSTdata:=''
	oWeb:Open( "POST", cUrl, .F. )
	oWeb:Send( cPOSTdata )
	cReturn := oWeb:ResponseBody()
RECOVER USING oErr
	cReturn := "!ERROR!" + CRLF + oErr:Description
END SEQUENCE
RETURN cReturn
zolysoftsolutions
WOW !! Super. Thank you very much EDK.
I'ts amazing and it's working fine.
Thanks again,
Zoli B.
Open eyes for you!
Does this work for https websites?
edk wrote: Tue Nov 12, 2019 2:40 pm
Function Main()
Local cPOSTdata
//Init
RECOVER
     oWeb:=""
END SEQUENCE
IF EMPTY(oWeb)
	MsgDebug( cResp )
	MsgDebug( hResp )
//Close
oWeb:Abort()
Local cReturn
RECOVER USING oErr
END SEQUENCE
RETURN cReturn
For me it works with https with the TLS 1.2 protocol http://hmgforum.com/viewtopic.php?p=66777#p66777
