Creation of a "Custom" Object
Red2
DBs Used: DBF, FoxPro, Visual FoxPro
Has thanked: 16 times
Been thanked: 3 times
Post by Red2 » Sun Aug 11, 2019 11:09 pm
Hello All,
I am still rather new to HMG. HMG has some really GREAT capabilities but they seem to be absent from the help file.
For example, a custom object could be very helpful in my current project. In a forum post, (viewtopic.php?f=5&t=4511&p=43036&hilit=HBClass#p43036), I saw some simple code I have adapted (below).
#include "hbclass.ch"
public oMyObj
oMyObj := CreateNewObj()
class CreateNewObj
	data ReadOnly	AS	character	INIT "ReadOnly"
	data Hidden	as	character	init "Hidden"
end class
Unfortunately I have not found documentation on HMG's implementation of "hbclass.ch" and CLASS ... END CLASS to help me.
My Question:
1) Can HMG assign a "Value" property to each such that the following will be valid? oMyObj:ReadOnly:Value and oMyObj:Hidden:Value
2) Where might I find good references that might explain or document the use of "hbclass.ch" and CLASS ... END CLASS in HMG?
3) Also, are there better or other ways to create and manipulate a custom object?
Any help you would be kind enough to point me to would be greatly appreciated!
Thank you, Red2
Has thanked: 202 times
Been thanked: 34 times
Post by danielmaximiliano » Mon Aug 12, 2019 12:33 am
Hi Red2
See http://www.kresin.ru/en/hrbfaq_3.html chapter 3.3
[CREATE] CLASS <cClassName> [ FROM | INHERIT <cSuperClass1> [, ... ,<cSuperClassN>] ]
                [ MODULE FRIENDLY ] [ STATIC ] [ FUNCTION <cFuncName> ]
      [HIDDEN:]
         [ CLASSDATA | CLASSVAR  | CLASS VAR <DataName1>]
         [ DATA | VAR  <DataName1> [,<DataNameN>] [ AS <type> ] [ INIT <uValue> ]
                [[EXPORTED | VISIBLE] | [PROTECTED] | [HIDDEN]] [READONLY | RO] ]
         [ METHOD <MethodName>( [<params,...>] ) [CONSTRUCTOR] ]
         [ METHOD <MethodName>( [<params,...>] ) INLINE <Code,...> ]
         [ METHOD <MethodName>( [<params,...>] ) BLOCK  <CodeBlock> ]
         [ METHOD <MethodName>( [<params,...>] ) EXTERN <funcName>([<args,...>]) ]
         [ METHOD <MethodName>( [<params,...>] ) SETGET ]
         [ METHOD <MethodName>( [<params,...>] ) VIRTUAL ]
         [ METHOD <MethodName>( [<params,...>] ) OPERATOR <op> ]
         [ ERROR HANDLER <MethodName>( [<params,...>] ) ]
         [ ON ERROR <MethodName>( [<params,...>] ) ]
      [PROTECTED:]
      [VISIBLE:]
      [EXPORTED:]
      [FRIEND CLASS <ClassName,...>]
      [FRIEND FUNCTION <FuncName,...>]
      [SYNC METHOD <cSyncMethod>]
      ENDCLASS [ LOCK | LOCKED ]
PD: If we talk about HMG we are on the graphical part in Windows environment. if we talk about the programming language we are talking about Harbour
.·`.HMG : It's magic !
Whatsapp. : +54901169026142
Telegram Name : DaNiElMaXiMiLiAnO
IMATECH
Has thanked: 1 time
Post by IMATECH » Mon Aug 12, 2019 4:10 am
OOP Sample !
Take a look here: viewtopic.php?f=35&t=2513&p=22112
M., Ronaldo
By: IMATECH
Imation Tecnologia
Anand
Has thanked: 137 times
Been thanked: 61 times
Post by Anand » Mon Aug 12, 2019 9:47 am
Hi Red2
My Report Class is based on custom class object.
viewtopic.php?p=51251#p51251
You can check the source, if it helps.
Anand
Red2
Post by Red2 » Tue Aug 13, 2019 1:06 am
Thank you all for your very generous help and suggestions. I really appreciate it.
Something has come up and I will not be able to dig into this for a week or two but I will then.
Thanks again! Red2
