GRID CHANGE COL
- tomtagaris
GRID CHANGE COL
I WANT TO LEARN HOW TO CHANGE FROM ONE COL TO THREE COL IN GRID WHEN I PUSH ENTER BUTON
PLEASE HELP
THANKS
TOM TAGARIS
PLEASE HELP
THANKS
TOM TAGARIS
Re: GRID CHANGE COL
Hi Tom.
I'm not sure if I understood your request correctly (my English is not very good) but I made an example: after editing the field in the first column, the next column is skipped and jumped to the third column.
Edk.
Local aRows [20] [3]
DEFINE WINDOW Form_1 ;
WIDTH 800 ;
HEIGHT 550 ;
TITLE 'Hello World!' ;
MAIN
aRows [1] := {'Simpson','Homer','555-5555'}
aRows [2] := {'Mulder','Fox','324-6432'}
aRows [3] := {'Smart','Max','432-5892'}
aRows [4] := {'Grillo','Pepe','894-2332'}
aRows [5] := {'Kirk','James','346-9873'}
aRows [6] := {'Barriga','Carlos','394-9654'}
aRows [7] := {'Flanders','Ned','435-3211'}
aRows [8] := {'Smith','John','123-1234'}
aRows [9] := {'Pedemonti','Flavio','000-0000'}
aRows [10] := {'Gomez','Juan','583-4832'}
aRows [11] := {'Fernandez','Raul','321-4332'}
aRows [12] := {'Borges','Javier','326-9430'}
aRows [13] := {'Alvarez','Alberto','543-7898'}
aRows [14] := {'Gonzalez','Ambo','437-8473'}
aRows [15] := {'Batistuta','Gol','485-2843'}
aRows [16] := {'Vinazzi','Amigo','394-5983'}
aRows [17] := {'Pedemonti','Flavio','534-7984'}
aRows [18] := {'Samarbide','Armando','854-7873'}
aRows [19] := {'Pradon','Alejandra','???-????'}
aRows [20] := {'Reyes','Monica','432-5836'}
@ 50,10 GRID Grid_Master ;
WIDTH 760 ;
HEIGHT 180 ;
HEADERS {'Last Name','First Name','Phone'} ;
WIDTHS {140,140,140};
ITEMS aRows ;
VALUE {1,1} ;
TOOLTIP 'Editable Grid Control' ;
EDIT ;
JUSTIFY { GRID_JTFY_CENTER,GRID_JTFY_RIGHT, GRID_JTFY_RIGHT } ;
CELLNAVIGATION ;
ON INPLACEEDITEVENT ProcGridInplaceEditEvent()
@ 240,10 GRID Grid_Detail ;
WIDTH 760 ;
HEIGHT 180 ;
ITEMS aRows ;
VALUE 1 ;
EDIT ;
ON HEADCLICK { {||MsgInfo('Click 1')} , {||MsgInfo('Click 2')} , {||MsgInfo('Click 3')} } ;
JUSTIFY { GRID_JTFY_LEFT,GRID_JTFY_CENTER, GRID_JTFY_CENTER };
CENTER WINDOW Form_1
ACTIVATE WINDOW Form_1
FUNCTION ProcGridInplaceEditEvent()
Local lCellNavigation := _HMG_SYSDATA [ 32 ] [_HMG_SYSDATA [ 203 ]]
Static lInitByDblClick := .F.
DO CASE
CASE This.IsInplaceEditEventInit == .T.
lInitByDblClick := _HMG_GridEx_InplaceEdit_nMsg == WM_LBUTTONDBLCLK
CASE This.IsInplaceEditEventRun == .T.
CASE This.IsInplaceEditEventFinish == .T.
IF lCellNavigation
IF _HMG_SYSDATA [ 15 ] [_HMG_SYSDATA [ 203 ]] = 1 //first column
_HMG_SYSDATA [ 15 ] [_HMG_SYSDATA [ 203 ]] := _HMG_SYSDATA [ 15 ] [_HMG_SYSDATA [ 203 ]] + IF (lInitByDblClick, 2, 1) //skip one column
IF _HMG_SYSDATA [ 340 ] = 1 //first column
_HMG_SYSDATA [ 340 ] := _HMG_SYSDATA [ 340 ] + IF (lInitByDblClick, 2, 1) //skip one column
ENDCASE
- tomtagaris
Re: GRID CHANGE COL
thank you so much adk for the reply the program works but because the grid have five col and in the COLUMNWHEN { { || .t. },{ || .T. }, { || .t. }, { || .t. }, { || .f. }} five col is .f. have this error see in pfoto
thanks
thanks
- 2019-07-25.png (290.2 KiB) Viewed 3805 times
Re: GRID CHANGE COL
I'm sorry, but without providing more details, especially the source code, I can not help.
Besides, my code is a "dirty", and it certainly will not work in any case.
Despite this, my example, extended with the COLUMNWHEN clause, works correctly:
WIDTH 800 ;
HEIGHT 550 ;
MAIN
aRows [1] := {'Simpson','Homer','555-5555','non editable','1'}
aRows [2] := {'Mulder','Fox','324-6432','non editable','2'}
aRows [3] := {'Smart','Max','432-5892','non editable','3'}
aRows [4] := {'Grillo','Pepe','894-2332','non editable','4'}
aRows [5] := {'Kirk','James','346-9873','non editable','5'}
aRows [6] := {'Barriga','Carlos','394-9654','non editable','6'}
aRows [7] := {'Flanders','Ned','435-3211','non editable','7'}
aRows [8] := {'Smith','John','123-1234','non editable','8'}
aRows [9] := {'Pedemonti','Flavio','000-0000','non editable','9'}
aRows [10] := {'Gomez','Juan','583-4832','non editable','10'}
aRows [11] := {'Fernandez','Raul','321-4332','non editable','11'}
aRows [12] := {'Borges','Javier','326-9430','non editable','12'}
aRows [13] := {'Alvarez','Alberto','543-7898','non editable','13'}
aRows [14] := {'Gonzalez','Ambo','437-8473','non editable','14'}
aRows [15] := {'Batistuta','Gol','485-2843','non editable','15'}
aRows [16] := {'Vinazzi','Amigo','394-5983','non editable','16'}
aRows [17] := {'Pedemonti','Flavio','534-7984','non editable','17'}
aRows [18] := {'Samarbide','Armando','854-7873','non editable','18'}
aRows [19] := {'Pradon','Alejandra','???-????','non editable','19'}
aRows [20] := {'Reyes','Monica','432-5836','non editable','20'}
WIDTH 760 ;
HEIGHT 180 ;
HEADERS {'Last Name','First Name','Phone','Col 4','Col 5'} ;
WIDTHS {140,140,140,140,140};
ITEMS aRows ;
VALUE {1,1} ;
EDIT ;
COLUMNWHEN { { || .t. },{ || .T. }, { || .t. }, { || .F. }, { || .T. }} ;
JUSTIFY { GRID_JTFY_CENTER,GRID_JTFY_RIGHT, GRID_JTFY_RIGHT , GRID_JTFY_RIGHT , GRID_JTFY_RIGHT } ;
CELLNAVIGATION ;
WIDTH 760 ;
HEIGHT 180 ;
ITEMS aRows ;
VALUE 1 ;
EDIT ;
JUSTIFY { GRID_JTFY_LEFT,GRID_JTFY_CENTER, GRID_JTFY_CENTER, GRID_JTFY_CENTER, GRID_JTFY_CENTER };
DO CASE
IF lCellNavigation
ENDCASE
- tomtagaris
Re: GRID CHANGE COL
@ 250,20 GRID invoice ;
WIDTH 900 ;
HEIGHT 200;
HEADERS { 'Κωδικός','Είδος', 'Ποσότητα', 'Τιμή','Έκπτωση %','Σύνολο', 'Ποσό Φπα', 'ΦΠΑ','Μ.Μ'} ;
WIDTHS {75, 200,100, 100,100, 100, 100,50,50 };
COLUMNCONTROLS { { 'TEXTBOX' }, { 'TEXTBOX' },;
{ 'TEXTBOX', 'NUMERIC', '999999.999' }, ;
{ 'TEXTBOX', 'NUMERIC', '9999.99' }, ;
{ 'TEXTBOX', 'NUMERIC', '999,99' }, ;
{ 'TEXTBOX', 'NUMERIC', '999,999.99' }, ;
{ 'TEXTBOX', 'NUMERIC', '99' },{ 'TEXTBOX' }} ;
COLUMNWHEN { { || .t. },{ || .T. }, { || .t. }, { || .t. }, { || .f. }, { || .f. }, { || .F. },{ || .F. },{ || .F. }};
justify { 0,0, 1, 1, 1,1,1 ,1,1} ;
VALUE 1 ;
Edit ;
ON GOTFOCUS CalcFPA() ;
ON key (OnKeyx(),endfil());
ON INPLACEEDITEVENT OnKeyx()
function endfil()
local x:= KATAXORISI.invoice.Itemcount
local i:=KATAXORISI.invoice.value
IF HMG_GetLastVirtualKeyDown () == VK_DOWN //.and. i > x
if x>33 .and. i=x
msgbox('Το όριο εγγραφών στο τιμολόγιο είναι 33','Προσοχή!!!!!!!')
if KATAXORISI.invoice.value=x // aν ο δεικτης ειναι στην τελευταια εγγραφη τοτε προσθεσε και αλλη εγγραφη
KATAXORISI.invoice.additem( {"","",0,0,0,0,0,0,''} )
for i = 1 to KATAXORISI.invoice.Itemcount
KATAXORISI.invoice.value:=i
KATAXORISI.invoice.setfocus
// setproperty("KATAXORISI","invoice","CellEx ",i,4)
next
Function OnKeyx()
local i,nIctr
Local aValue := { }
// IF HMG_GetLastVirtualKeyDown() == 13 //F2
if This.IsInplaceEditEventInit == .T.
DO CASE
IF lCellNavigation
Endif
ENDCASE
IF This.IsInplaceEditEventFinish == .T.
i := KATAXORISI.invoice.value
aValue:= KATAXORISI.invoice.value //item( i )
nIctr := KATAXORISI.invoice.cell( i, 2)
if This.CellColIndex = 1 .and. ! empty(KATAXORISI.invoice.cell( i, 1))
Select 1
index on code to apoteke_code
seek KATAXORISI.invoice.cell( i, 1)
if found()
KATAXORISI.invoice.cell( i,1):=CODE
KATAXORISI.invoice.cell( i,2):=EIDOS
KATAXORISI.invoice.cell( i,3):=0
KATAXORISI.invoice.cell( i,4):=PRICE
KATAXORISI.invoice.cell( i,5):=ekptosi
KATAXORISI.invoice.cell( i,6):=0
KATAXORISI.invoice.cell( i,7):=0
KATAXORISI.invoice.cell( i,8):=FPA
KATAXORISI.invoice.cell( i,9):= APOTEKE->MM
msginfo('O Kωδικός δέν Υπαρχει..','Προσοχή')
if This.CellColIndex=2 .and. empty(KATAXORISI.invoice.cell( i, 1))
SERCH2( KATAXORISI.invoice.cell( i, 2))
WIDTH 900 ;
HEIGHT 200;
VALUE 1 ;
Edit ;
function endfil()
if x>33 .and. i=x
next
Function OnKeyx()
local i,nIctr
Local aValue := { }
DO CASE
IF lCellNavigation
Endif
ENDCASE
Select 1
if found()
- tomtagaris
Re: GRID CHANGE COL
this is the code
thanks
thanks
Re: GRID CHANGE COL
Hi.
From the given piece of code, I still do not have a full picture of the situation when the problem occurs.
My guess is that line 431 is Local lCellNavigation: = _HMG_SYSDATA [32] [_HMG_SYSDATA [203]]
You have mixed up various events and handle them with the same procedure, which can cause errors:
ON key (OnKeyx (), endfil ());
ON INPLACEEDITEVENT OnKeyx ()
Note that This.IsInplaceEdit* properties are only available for the OnInplaceEditEvent event, and you also refer to them in the OK KEY event. This also applies to the variable _HMG_SYSDATA [203]
Personally, I would make separate functions for these events.
You can still try to replace the variable reference _HMG_SYSDATA [203] to GetControlIndex (This.InplaceEditGridName, This.InplaceEditParentName) but the This.InplaceEdit* property is also only available for the OnInplaceEditEvent event.
The changed procedure looks like this:
In addition, you can simplify the function if your Grid does not have Cell Navigation:
Local index := GetControlIndex ( This.InplaceEditGridName , This.InplaceEditParentName )
DO CASE
CASE This.IsInplaceEditEventFinish == .T. .AND. index > 0
IF _HMG_SYSDATA [ 32 ] [index] //is Cell Navigation?
IF _HMG_SYSDATA [ 15 ] [index] = 1 //first column
_HMG_SYSDATA [ 15 ] [index] := _HMG_SYSDATA [ 15 ] [index] + IF (lInitByDblClick, 2, 1) //skip one column
ENDCASE
DO CASE
ENDCASE
- tomtagaris
Re: GRID CHANGE COL
THANK YOU adk FOR THE BEAUTIFUL WORLD WORKING NOW VERY WELL
BECAUSE COME FROM CLIPPER I DO NOT UNDERSTAND WHAT THIS IS _HMG_SYSDATA [ ΧΧ] PLEASE CAN YOU explain
SORY FROM MY ENGLISH
THANKS
TOMTAGARIS
THANKS
TOMTAGARIS
Re: GRID CHANGE COL
_HMG_SYSDATA is a multidimensional matrix in which all the parameters necessary for the functioning of HMG are stored.
See the contents of the file h_init.prg, there are basic references - the file is placed in the HMG installation folder in the SOURCE subfolder.
Understanding individual _HMG_SYSDATA arrays requires reanalyzing HMG sources. Therefore, source codes containing direct references to _HMG_SYSDATA and their manipulation affect the entire HMG and may lead to its unstable work.
The _HMG_SYSDATA [340] variable stores the number of the currently edited cell.
Normally, after editing the cell, HMG increases the value of _HMG_SYSDATA [340] by one (ie it will go to the next column - unless it is the last one, then it gets the value 1) and restart the editing process the cell number _HMG_SYSDATA [340].
In the case of _HMG_SYSDATA [340] ++, we cheat HMG.
In order to skip the edition of column No. 2 we implement the following scenario: when we finish editing the cell, where _HMG_SYSDATA [340] = 1, change the value _HMG_SYSDATA [340] to 2, then after the event, HMG will increase the value by one again, then _HMG_SYSDATA [340] will have a value of 3, and HMG will start editing cell number 3.
- tomtagaris
Re: GRID CHANGE COL
Thank you very much
your help was valuable
tomtagaris
tomtagaris
