Posts: 1068 Joined: Fri Aug 01, 2008 5:42 am
Post
by gfilatov » Thu Jun 11, 2009 12:42 pm
Alex Gustow wrote: Hi all!
I tried updated sample (Win98, Harbour 1.1.0.dev (Rev. 11020), HMGExt 1.6.67 ).
1. Compile time warning
Warning W8017 c:\borland\bcc55\include\winuser.h 3536: Redefenition of
'LWA_ALPHA' is not identical
Hi Alex,
Thanks for reporting!
You are right (for
Borland C ).
I've changed the definition for
MinGW at the C-level:
#pragma BEGINDUMP
#if defined ( __MINGW32__ )
#define _WIN32_WINNT 0x0500
#endif
#include <windows.h>
#include "hbapi.h"
jrendon
Posts: 92 Joined: Thu Aug 14, 2008 9:21 pm
Post
by jrendon » Thu Jun 11, 2009 7:52 pm
gfilatov wrote: jrendon wrote:
Hi Grigory !
when compiling the code your post the following error appears:
Start...
DEMO.prg: In function `HB_FUN_SETTRANSPARENT':
DEMO.prg:57: error: `LWA_ALPHA' undeclared (first use in this function)
DEMO.prg:57: error: (Each undeclared identifier is reported only once
DEMO.prg:57: error: for each function it appears in.)
Finished With Errors.
Can you help me please?
Saludos, Fernando Chirico.
Yes me to the same error on this line code
pfnSetLayeredWindowAttributes((HWND) hb_parnl (1), 0, hb_parni (2), LWA_ALPHA);
Hi Juan Rendon,
Please be so kind to try an updated sample below:
* Copyright 2002-2009 Roberto Lopez <harbourminigui@gmail.com>
#include "minigui.ch"
Function Main()
Local nTra := 128, hWnd
DEFINE WINDOW WinTR ;
WIDTH 300 ;
HEIGHT 300 ;
TITLE 'Transparent window' ;
MAIN ;
NOSIZE NOMAXIMIZE ;
ON INIT ( hWnd := GetFormHandle('WinTR'), SetTransparent(hWnd, nTra) )
@ 200,100 BUTTON But1 ;
CAPTION "Click Me" ;
HEIGHT 35 WIDTH 100 ;
ACTION ( nTra := IIF(nTra == 128, 255, 128), SetTransparent(hWnd, nTra) )
CENTER WINDOW WinTR
ACTIVATE WINDOW WinTR
#pragma BEGINDUMP
#define LWA_ALPHA 0x02
#include "hbapi.h"
HB_FUNC( SETTRANSPARENT )
typedef BOOL (__stdcall *PFN_SETLAYEREDWINDOWATTRIBUTES) (HWND, COLORREF, BYTE, DWORD);
PFN_SETLAYEREDWINDOWATTRIBUTES pfnSetLayeredWindowAttributes = NULL;
HINSTANCE hLib = LoadLibrary("user32.dll");
if (hLib != NULL)
pfnSetLayeredWindowAttributes = (PFN_SETLAYEREDWINDOWATTRIBUTES) GetProcAddress(hLib, "SetLayeredWindowAttributes");
if (pfnSetLayeredWindowAttributes)
SetWindowLong((HWND) hb_parnl (1), GWL_EXSTYLE, GetWindowLong((HWND) hb_parnl (1), GWL_EXSTYLE) | WS_EX_LAYERED);
if (!hLib)
FreeLibrary(hLib);
#pragma ENDDUMP
I hope that helps.
Hi Grigory !
is working now
thank's
jrendon
Post
by jrendon » Thu Jun 11, 2009 8:59 pm
Set Language to Spanish
en este ejemplo que hice gracias a Grigory me salieron varias dudas
1.- como puedo insertar un objeto arriba de una imagen y que se pueda utilizar por ejemplo el slider por encima de la imagen (ya cambie el orden de los controles y si se pone el slider encima pero no tengo control sobre el)
2.- En el slider no existe la propiedad Transparent ( Creo que esto es para Roberto)
3.- Como hacer que la ventana quede transparente pero los objetos queden normales como controles o imagen ( creo que es para Grigory)
Gracias
Set Language to English (Powered by google)
in this program that I thank Grigory took me several questions
1 .- How can I put an object up an image that can be used eg the slider above the image (and change the order of the checks and if we put the slider on top but I have no control over)
2 .- In the slider Transparent property does not exist (I believe this is Roberto)
3 .- How to make the window is transparent but the objects are normal controls or an image (I think it is for Grigory)
Thank you
jrendon
Post
by jrendon » Thu Jun 11, 2009 9:01 pm
ups sorry, the program is here...
test1.rar
window transparent (45.52 KiB) Downloaded 360 times
fchirico
Posts: 324 Joined: Sat Aug 23, 2008 11:27 pm
Post
by fchirico » Fri Jun 12, 2009 2:17 am
jrendon wrote: ups sorry, the program is here...
Excelente !!!
Seguramente me servirá de inspiración
Gracias por compartir.
fchirico
Post
by fchirico » Fri Jun 12, 2009 2:53 am
If we join the examples of Esgici and Jrendon ....
CuckoClok_Transparente.zip
(9.99 KiB) Downloaded 345 times
jrendon
Post
by jrendon » Fri Jun 12, 2009 3:50 am
fchirico wrote: jrendon wrote: ups sorry, the program is here...
fchirico good inspiration jejeje
jrendon
Post
by jrendon » Fri Jun 12, 2009 6:41 am
another example
and this is the program
Juan Rendon
test.rar
(46.84 KiB) Downloaded 360 times
jairpinho
Posts: 420 Joined: Mon Jul 18, 2011 5:36 pm
Post
by jairpinho » Fri Aug 16, 2019 12:01 am
gfilatov wrote: ↑ Wed Jun 10, 2009 7:15 am
jrendon wrote: Hi all
how create a window transparent
i see one example many years ago on version 1.xx of minigui, and now need this example.
Hi Juan Rendón,
Please try the following sample:
Function Main()
WIDTH 300 ;
HEIGHT 300 ;
MAIN ;
NOSIZE NOMAXIMIZE ;
CENTER WINDOW WinTR
#pragma BEGINDUMP
#include "hbapi.h"
if (hLib != NULL)
if (!hLib)
FreeLibrary(hLib);
#pragma ENDDUMP
I need to develop an application that the window main would have to be transparent and be based on a png picture this is possible?
It would be a window for game with the format of a picture png and all buttons on this images, would be next to the example: C: \ hmg.3.4.4 \ SAMPLES \ Miscellaneous \ ScreenSplash but with the main window with the possibility to create by ide
