QR Code in HMG
Re: QR Code in HMG
Muchas gracias por tu tiempo. Edk
Voy a hacer la prueba con tu código, ya que yo estoy utilizando:
@ 229,007 PRINT IMAGE System.TempFolder+"CB_QRCODE.jpg" WIDTH 32 HEIGHT 32
Sirve que así no genero el archivo .jpg físico.
Thank you so much for your time. Edk
I'm going to do the test with your code, since I'm using:
@ 229.007 PRINT IMAGE System TempFolder + "CB_QRCODE .jpg" WIDTH 32 HEIGHT 32
It serves so that the physical JPG file does not generate.
Y también modificaré los cambios que indicas.
And I will also change the changes you indicate.
edk
Re: QR Code in HMG
Post by edk »
The error is due to an incorrectly calculated QR code width, resulting in an invalid jpg file.
radohabjan
Re: QR Code in HMG
Post by radohabjan »
Thx Edk for solve problem with QR
I reported this problem already in 2015:
http://www.hmgforum.com/viewtopic.php?f ... 510#p43023
Now I don't need anymore external QR Code generator in my program.
br Rado
edk
Re: QR Code in HMG
Post by edk »
radohabjan wrote: Mon Nov 27, 2017 9:44 am I reported this problem already in 2015:
Wow, I haven't seen this post before. :o :shock:
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: QR Code in HMG
Post by dragancesu »
if someone needs QRcode generator from command prompt
https://sourceforge.net/projects/zint/
And here (Serbia) we will need to put qr code on some invoices, you have a program on the link that works in windows command prompt and creates qr code as an image, there are many options
Re: QR Code in HMG
i have download HMG some week ago and found that BUG still exist in \SOURCE\h_HMG_Zebra.Prg :o
so i like to ask how to get latest Version of HMG \SOURCE\*.PRG :?:
Re: QR Code in HMG
I'm afraid there is no newer version.
Try to search reported bugs and solutions on the forum
Re: QR Code in HMG
En la página anterior de este mismo post, esta la solución dada por el amigo EDK...
On the previous page of this same post, there is the solution given by friend EDK ...
Re: QR Code in HMG
andyglezl wrote: Sat Oct 19, 2019 1:08 pm En la página anterior de este mismo post, esta la solución dada por el amigo EDK...
Yes, i found that Msg from EDK
thats why i'm asking for "more" Hotfix (if need)
@Marek : how to find Hotfix :?:
Re: QR Code in HMG
You need to apply changes to hmg source code and recompile it by yourself
