mapping network drive inside application -is it possible?
franco
Re: mapping network drive inside application -is it possible?
Post by franco »
now error says failed to connect to server.
I am confused. This is exactly what I would like to do.
I am trying this on my 3.2 machine, would this be a problem.
Franco
All The Best,
Franco
Canada
Franco, I have prepared a working demo version.
I have created a Gmail account for testing purposes.
I've previously submitted the wrong AddAttachment method syntax (sorry, but I wrote from my faulty memory :oops: ).
Correct syntax should be:
:AddAttachment ("c:\temp\readme.txt")
I have not tested on HMG 3.2, but since version 3.3.1 it works fine.
CDO.7z
(966.3 KiB) Downloaded 428 times
Thanks Krzysztof!
franco
Post by franco »
Thank you so much for your help. I think I have to set my gmail account to insecure for sending mail because google locks this out on a secure
account.
This is whats so great about HMG Forum.
I will let you know how I make out ........... Franco ;)
All The Best,
Franco
Canada
franco
Post by franco »
SUCCESS.......... That was it I had to set the high security off in my gmail. I think the way to do this is to have separate gmail account for
using internal sending mail from.
It would be nice if you could hide the email it was sent from and show only the sm_from on the recievers email for responses. This would
make it so special email address would be only for sending.
Now we can make an email program using this for sending. Right now sending param will work great.
Thanx again for all your time and help .................. Franco
All The Best,
Franco
Canada
tomtagaris
Post by tomtagaris »
About CDO.7z
how to Add Attachment more one files
is impossible ;
thanks
tom tagaris
tomtagaris wrote: Tue Aug 06, 2019 8:27 am About CDO.7z
is impossible ;
thanks
tom tagaris
Just add next property, ex:
:AddAttachment ("c:\temp\first.txt")
:AddAttachment ("c:\temp\second.txt")
and so on ...
Note to provide the full attachment path.
tomtagaris
ok thanks
tom
