Print preview in HMG Console mode
Hello All,
Is there any way to preview the reports in console mode of HMG?
Just now one of my friends (Mr. Manohar Maski) asked me how to see print preview with HMG in console mode. I don't know.
He used SELECT PRINTER command and is very happy to see his old Clipper app is now printing on Windows printers :)
Thanks in advance. :)
jparada
Re: Print preview in HMG Console mode
Post by jparada »
Hi Sudip,
Please take a look:
http://hmgforum.com/viewtopic.php?f=5&t=1504
Maybe this will help to you
Best Regards
Javier
With Javier's help, I had created a small sample. I think this would work.
define window dummy at 0,0 width 0 height 0 main nocaption nosysmenu on init startmain()
end window
activate window dummy
function startmain
?"Now starting the program."
wait
select printer default preview
start printdoc
start printpage
@ 20,20 print "This is a test print"
end printpage
end printdoc
?"Now ending the program"
wait
endmain()
return nil
function endmain
release window dummy
return nil
Fine example. Till now, I thought it isn't possible because of not activation main window.
Thanks, Rathi!
Hello,
Thank you Rathi.
Here is my code: (some idea taken from J.Parada and I wrote it before seeing Rathi's code.)
// here is our main window
function Main()
   define window winMain at 0, 0 width 100 height 100 main noshow ;
      on init ConsoleMain()
   end window
   activate window winMain
   return nil
// here comes our old clipper / harbour console codes
function ConsoleMain()
   clear screen
   @ 1, 1 to maxrow()-1, maxcol()-1 double
   @ maxrow()-2, 1 say "Press any key to start print preview in console mode ..."
   inkey(0)
   PrintTest()
   clear screen
   @ maxrow()-2, 1 say "Print test done. Press any key to quit ..."
   inkey (0)
   thiswindow.release()
   retur nil
// here comes print test
Function PrintTest()
   SELECT PRINTER DEFAULT PREVIEW
   START PRINTDOC NAME "Print from HMG Console Mode"
   START PRINTPAGE
   @ 100, 100 print "This is print test from HMG Console Mode"
   END PRINTPAGE
   END PRINTDOC
   return nil
I'm returning to this topic. I want to ask if it's possible to move focus to console and from console to window?
I've used Rathi' sample, it works fine, but after running program, text console doesn't get focus. We need to move to it via ALT-Tab or mouse key.
When I activate window form, focus is still at console...
Marek
I am afraid it is not possible.
The reason is, after we give the command end printdoc the preview window is released, however the dummy window is not released. If we release that window, the application is closed immediately.
I think Roberto can help in this regard.
rathinagiri wrote:I am afraid it is not possible.
If you want to set the focus to a non HMG generated window (like console) you must code a little of C and WinAPI.
The easier way is to locate the window by his title and then operate on it to (ie) give the focus.
AFAIR, at least one of the Grigory's utilities does it.
I gues that him is the right person to help you here.
mol wrote:I'm returning to this topic. I want to ask if it's possible to move focus to console and from console to window?
Hi Marek,
Please be so kind to revise the following mixed mode sample:
#include "minigui.ch"
    SET STATIONNAME TO "MAINPROC"
    _HMG_Commpath:= GetCurrentFolder()+"\"
    DEFINE WINDOW Form_1 ;
        WIDTH 640 HEIGHT 480 ;
        TITLE 'Harbour MiniGUI Demo' ;
        MAIN ;
        FONT 'Arial' SIZE 10
        DEFINE LABEL Label1
            ROW 10
            COL 10
            VALUE "Good morning"
        END LABEL
        DEFINE GETBOX Box11
            ROW 10
            COL 100
            VALUE 2.5
            PICTURE '999,999,999,999.9999'
        END GETBOX
        DEFINE BUTTON Btn1
            ROW 50
            COL 10
            CAPTION 'DOS 1'
            ACTION THIS.CAPTION:=ALLTRIM(STR(GETDATA(FN1())))
        END BUTTON
        DEFINE BUTTON Btn2
            ROW 100
            COL 10
            CAPTION 'Message'
            ACTION  FN2(3)
        END BUTTON
        DEFINE BUTTON Btn4
            ROW 150
            COL 10
            CAPTION 'EXIT'
            ACTION Form_1.release
        END BUTTON
    HideConsole()
    Form_1.Center()
    Form_1.Activate()
FUNCTION FN1()
LOCAL r1 := 0
LOCAL r2 := 0
MEMVAR GetList
    HIDE WINDOW Form_1
    ShowConsole()
    CLEAR SCREEN
    @ 10,10 SAY ' S1 ' GET r1 pict '9999'
    @ 12,10 SAY ' S2 ' GET r2 pict '9999'
    READ
    SENDDATA("MAINPROC",R2)
    HideConsole()
    RESTORE WINDOW Form_1
FUNCTION FN2(n)
LOCAL i
    HIDE WINDOW Form_1
    ShowConsole()
    CLEAR SCREEN
    FOR i:=1 TO n
        ?i
    WAIT
    HideConsole()
    MsgBox('bla'+TRANSFORM(n,'99'),'Title')
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
#include "hbapiitm.h"
HB_FUNC( HIDECONSOLE )
    ShowWindow(( HWND) FindWindow( NULL, "demo" ), SW_MINIMIZE);
HB_FUNC( SHOWCONSOLE )
    ShowWindow(( HWND) FindWindow( NULL, "demo" ), SW_RESTORE);
#pragma ENDDUMP
Hope that give you an idea(s) :idea:
Nice example Grigory. Thanks. :)
