with
File or Directory not found
so i need a "Makeit" which i don't have ...
[/quote]
MinGW/Native Windows
PostgreSQL for Windows can be built using MinGW, a Unix-like build
environment for Microsoft operating systems, or using Microsoft's
Visual C++ compiler suite. The MinGW build variant uses the normal
build system described in this chapter; the Visual C++ build works
completely differently and is described in the documentation. It is a
fully native build and uses no additional software like MinGW. A
ready-made installer is available on the main PostgreSQL web site.
The native Windows port requires a 32 or 64-bit version of Windows 2000
or later. Earlier operating systems do not have sufficient
infrastructure (but Cygwin may be used on those). MinGW, the Unix-like
build tools, and MSYS, a collection of Unix tools required to run shell
scripts like "configure", can be downloaded from
http://www.mingw.org/.
Neither is required to run the resulting binaries; they are needed only
for creating the binaries.
To build 64 bit binaries using MinGW, install the 64 bit tool set from
http://mingw-w64.sourceforge.net/, put its bin directory in the PATH,
and run "configure" with the "--host=x86_64-w64-mingw32" option.
After you have everything installed, it is suggested that you run psql
under "CMD.EXE", as the MSYS console has buffering issues.
