HMG 3.6 (64 bit version)
Red2
Re: HMG 3.6 (64 bit version)
Post by Red2 »
Thank you Rathinagiri,
I, and I believe others, will really appreciate this official "compete" 3.6 release.
Thank you again for all of your efforts!
Hola a Todos: estos dias estuve integrando Qwen 3.8 en una CUBE modo local, le pedi que revisará IDE_CODESOURCE.prg y lo dividiera en modulos.
genero un IDE con modulos que viene bien para poder mejorarlo y no tener que revisar creo las 50.000 lineas de codigo, ahora es mas comodo trabajar.
tambien le pedi revisar la libreria HMG en busca de fallos y corrigio muy poco. también le pedí optimizar Tooltip y MSGxx , nuevos script para compilar la libreria, crear el IDE unicode con Harbour64, mientras compilaba Harbour desde los fuentes en las versiones 32 y 64 bits con Mingw 32 y Mingw64 desde WinLibs.com
dejo un Flujo de trabajo del resultado :
Hi everyone: I’ve been integrating Qwen 3.8 into a local CUBE setup recently; I asked it to review `IDE_CODESOURCE.prg` and split it into modules.
It generated a modular IDE, which makes improvements much easier—avoiding the need to sift through what I believe are 50,000 lines of code—so working with it is now much more convenient.
I also asked it to check the HMG library for bugs (though it fixed very few) and to optimize the Tooltip and MSGxx functions. Additionally, I had it create new scripts to compile the library and build the Unicode IDE using Harbour64, all while compiling Harbour from source for both 32-bit and 64-bit versions using MinGW32 and MinGW64 from WinLibs.com.
Here is the workflow of the result:
| Component | Versión | Ubicación / Location |
| Harbour | 3.2.1dev (r2609180937), ©1999-2025 | C:\hmg.3.7\harbour64\bin |
| GCC | x86_64-posix-seh-rev1, MinGW-Builds 16.1.0 | C:\hmg.3.7\mingw64\bin |
| HB_COMPILER | mingw64 → libs en LIB-64 | |
| Harbour | 3.2.1dev (r2609180937), ©1999-2025 | C:\hmg.3.7\harbour\bin |
| GCC | i686-ucrt-posix-dwarf r3 (Brecht Sanders) 14.2.0 | C:\hmg.3.7\mingw\bin |
| HB_COMPILER | mingw → libs en lib | |
Ejecutar / Run : C:\hmg.3.7\BuildLib32.bat
Ejecutar / Run : C:\hmg.3.7\BuildLib64.bat
Ejecutar / Run : C:\hmg.3.7\BuildIDE.bat
Ejecutar / Run : C:\hmg.3.7\ide\unicode.exe
Los scripts de construcción de libhmgxx.a tiene barra de progreso como asi tambien la construccion del IDE , ya no es un proceso silencioso
The libhmgxx.a construction scripts have a progress bar as well as the construction of the IDE, but it is not a silent process
Nuevo / New : Toolbutton solo accesible desde NewForm()
nuevo / New : ToolTip
ejemplos / Sample : C:\hmg.3.7\samples\Controls\ToolTip\ToolTip_Styles
Reference : file:///C:/hmg.3.7/doc/data/settooltipstyle.htm
Nuevo / New : MessageBox
Ejemplo / Sample : C:\hmg.3.7\samples\Controls\MessageBox\MessageBox_Styles
Reference : file:///C:/hmg.3.7/doc/data/SetMsgBoxModern.htm
ANSI declarado Obsoleto.
ANSI declared obsolete.
Se elimino Tooltip de la solapa configuracion del inspector de proyecto en Unicode , molesta y tiene mala lectura. Por ende al crear un proyecto nuevo se agregan al .hbc
sino se puede copiar desde aqui : C:\hmg.3.7\source\unicode\Config.hbc
If I delete Tooltip from the Unicode configuration of the project inspector, it is annoying and has bad reading. Why do you want to create a new project? Add to .hbc
You can copy it from here: C:\hmg.3.7\source\unicode\Config.hbc
como es un .rar muy grande que pesa unos 540mb que no se puede subir aqui los invito a descargarlo desde mi canal de telegram que esta en la firma de este POST.
Thanks Daniel
Steed
Post by Steed »
Gracias
Buen dia a todos:
viendo las aplicaciones actuales de agentes de IA, Navegadores WEB, etc. Veo que las interfaces GUI esta marcada por elementos (controles) sencillos dejando de lado toscos menues , recuadros cuadrados, etc algo que se viene arrastrando desde decadas. hoy las interfaces son mas lindas de ver y simples.
como les dije que actualemente estoy haciendo con mi tiempo libre un poco de programacion y reparacion de equipos (soy técnico eléctronico) que tuve mucho tiempo olvidados :mrgreen:
esta demas decirle que estas implementacion como asi tambien la correccion de build.bat y build64.bat en HMG.3.6 que queria lanzar ( no recuerdo si erá ViewReport.exe) ahora si lanza Notepad con el resultado de compilacion en caso de errores.
asi como tambien los ejemplos tienes 2 versiones (build.bat para los nostalgicos de 32 bits y build64.bat )
mas tarde subire las actualizaciones a mi grupo de telegram que esta en la firma de este post.
Captura de pantalla 2026-10-09 071709.png (127.26 KiB) Viewed 323 times
Captura de pantalla 2026-10-09 071611.png (40.41 KiB) Viewed 323 times
Captura de pantalla 2026-10-09 071524.png (37.77 KiB) Viewed 323 times
apais
Post by apais »
Hola Daniel
Podrías decirme que hardware estás usando para correr Qwen en modo local ?
Angel
Angel Pais
apais wrote: ↑Fri Oct 09, 2026 6:57 pm Hola Daniel
Angel
Hola :
Esa en una empresa lo hago remotamente mientras pruebo la instalacion, despues te doy el contexto del Harware que hay , que CUBE compraron.
Hola a Todos:
mientras pruebo Qwen 3.8 hice nuevas mejoras a HMG.3.7 beta.
les recuerdo que esta incluido Harbour y Harbour64, MinGW y MinGW64, el nuevo IDE, la nueva libreria.
nuevos Ejemplo con sus respectivos constructores (build y build64.bat) para compilar el sabor que quieran :D
les recuerdo que el archivo .rar esta disponible en mi grupo de Telegram porque pesa 560mb y aqui no tiene la capacidad para compartirlo.
nuevo ToolTip, TextBox, Frame, EditBox y RichEdit con contornos redondo al nuevo estilo de aplicaciones actuales.
ver : C:\hmg.3.7\samples\Basics\MAIN_AUTOADJUST_2
esta reflejado en la Referencia HMG para poder ver estas mejoras.
si ven posible mejoras enviar mensaje en telegram .
Captura de pantalla 2026-10-09 195724.png (158 KiB) Viewed 259 times
Hola a Todos:
El nuevo IDE hoy trabaja con las nuevas propiedades Rounded para Frame, TextBox, EditBox, Richedit.
Captura de pantalla 2026-10-10 212250.png (135.21 KiB) Viewed 131 times
Hola a Todos:
hoy correcciones en el inspector de objetos.
fuentes de verdad el manual de referencia y en generador de formularios al guardar dicho formularios.
Row / col
Heigth y Width
Captura de pantalla 2026-10-11 002532.png (123.36 KiB) Viewed 114 times
hoy estare publicando las correcciones en mi canal de telegram.
