Page 2 of 6
Re: HPDFPRINT IMAGE Image cannot be loaded
Posted: Fri Nov 22, 2019 3:59 pm
by mustafa
Será por el tamaño de la Imagen ?
He modificado mi SampleJPG y modifique medidas de tamaño
de JPG y Funciona PNG y JPG y he añadido TYPE JPG
Muy raro ? :oops: :(
*------------------------------------------------ Cuadro General ------------------------------*
     @ 005,005  HPDFPRINT RECTANGLE TO 292, 206 PENWIDTH 1 ROUNDED CURVE 1
     @ 007,007  HPDFPRINT RECTANGLE TO 290, 204            ROUNDED CURVE 1
     @ 021,025 HPDFPRINT IMAGE "Resource\Business-Pie.png" width 15 height 15
     @ 032,065 HPDFPRINT "DataBase WebCam Photo"  FONT "Times-Roman" SIZE 22 ITALIC
     @ 032,150 HPDFPRINT DTOC(DATE())             FONT "Times-Roman" SIZE 18 ITALIC
     @ 047, 060 HPDFPRINT IMAGE "Resource\00001.jpg"  WIDTH 50 HEIGHT 50 TYPE JPG   // WIDTH 55 HEIGHT 50
     @ 107, 100 HPDFPRINT IMAGE "Resource\00007.jpg"  WIDTH 50 HEIGHT 50 TYPE JPG   // WIDTH 55 HEIGHT 50    <-------  Modificado Tamaño
     @ 167, 030 HPDFPRINT IMAGE "Resource\00005.jpg"  WIDTH 85 HEIGHT 80 TYPE JPG   // WIDTH 85 HEIGHT 80
Posted: Sat Nov 23, 2019 7:26 pm
by franco
Could someone help figure this out'
This code works if:
1. I print it to printer and then in preview save to disk as pdf, then go out of program.
2. take picture then go out of program and edit picture with paint and do nothing but save as pdf. The file is much smaller then original.
Then I go back in program and do not take a new picture. Then print to pdf. It now works.
You need a laptop or windows tablet to use this so you can take a picture with internal camera.
If I use external camera or any hmg pre-printed jpeg files it works;
Put this code in a folder and complile or build with. build.bat
build.bat in this folder
@ECHO OFF
call c:\hmg.3.4.4\build.bat main %*
you will also need CAMERA.SWF in this folder
	LOCAL PD := .F.
	IF ! FILE('WEBCAM.HTML')
		WEBCAM('WEBCAM','CAMERA.SWF','300','300')
	READYCAM()
	IF MSGYESNO('Do You Want to Print to PDF')
		PD := .T.
		SELECT PRINTER PDF 'MiPDF.pdf' TO lSuccess
		IF LSUCCESS == .F.
			MSGINFO('PDF File Not Available')
		SELECT  PRINTER DEFAULT TO lSUCCESS preview ;
		ORIENTATION PRINTER_ORIENT_PORTRAIT ;
		PAPERSIZE PRINTER_PAPER_LETTER ;
		QUALITY PRINTER_RES_MEDIUM
	IF LSUCCESS == .F.
		MSGINFO('Printer Not Available')
		START PRINTDOC
		START PRINTPAGE
		PL := 8
		@ PL,10 PRINT ' Hello to all:'
		@ PL,170 PRINT 'Date: '+DTOC(DATE()) SIZE 10
		PL:= PL+20
		IF FILE(getcurrentfolder()+'\test.jpg')
			@ PL,10 PRINT IMAGE getcurrentfolder()+'\TEST.JPG' WIDTH 80 HEIGHT 60 TYPE JPG
		@ 100,90 PRINT 'End of Report:'
	END PRINTPAGE
	END PRINTDOC
	IF PD = .T.
		EXECUTE FILE 'MIPDF.PDF'
	PD := .F.
FUNCTION READYCAM(PICT)
IF !ISWINDOWACTIVE(CAMFORM)            //330        (GETDESKTOPwidth())-35
	DEFINE WINDOW CAMFORM AT 65,30 WIDTH 620  HEIGHT 310  TITLE 'Shot Image ** Escape to Cancel'  ICON 'WEBCAM.ICO' MODAL  SYSMENU .F. ;
		BACKCOLOR (143,200,220)
	ON KEY ESCAPE OF CAMFORM ACTION {||{ANS := 'F'},{CAMFORM.RELEASE}}
	DEFINE ACTIVEX ACTIVEX2
		ROW   10
		COL   7
		HEIGHT 300   //230   //300
		WIDTH 230
		PROGID "SHELL.EXPLORER.2"
	END ACTIVEX
	DEFINE BUTTON BUTTON1
        ROW    5  //250
        COL    350  //120
        WIDTH  100
        HEIGHT 100   //28
        ACTION SNAPSHOT()
        CAPTION "Snap Shot"
		PICTURE 'CAMERA'
        FONTNAME "Arial"
        FONTSIZE 10
		*visible .F.
    END BUTTON
		DEFINE BUTTON BUTTON2
        ROW    160 //250
        COL    350   //170  //120
        WIDTH  100
        HEIGHT 100   //28
        CAPTION "Exit"
		PICTURE 'hp_close'
        FONTNAME "Arial"
        FONTSIZE 10
		*visible .F.
    END BUTTON
	CAMFORM.ACTIVEX2.OBJECT:NAVIGATE(GETCURRENTFOLDER()+"\WEBCAM.HTML")
	CAMFORM.ACTIVATE
	MSGBOX('Not Available')
FUNCTION SNAPSHOT
CAMFORM.CAPTURE('TEST.JPG',15,7,300,230)
PLAYBEEP()
CAMFORM.RELEASE
FUNCTION WEBCAM
PRIVATE   _cfile, _cimage, _cwidth, _cheight
PARAMETER _cfile, _cimage, _cwidth, _cheight
_cfile:=_cfile+".html"
TEXT TO FILE &_cfile
<html>
	<body style="overflow: hidden; margin: 0; padding: 0;"
		ondragstart="return false;" ondrop="return false;" oncontextmenu="return false;" onmousedown="return false;">
		<PARAM NAME="SCALE" VALUE="exactfit">
		<embed src="&_cimage" quality="high" type="application/x-shockwave-flash" width="100%" height="100%"
		allowScriptAccess="always" menu="false">
		</body>
</html>
ENDTEXT
I have spent 2 weeks on this and am now using the print to printer a rename file name to pdf
I have also tried this with hpdfprint acts the same.
Is there a save as in hmg.3.4.4
Is there a way to (SAVE AS) the same name.pdf after the picture is captured to do what the disk in the print preview does.
Thanks to all
Franco
Posted: Thu Nov 28, 2019 12:20 am
by franco
Has anyone had a chance to try this.
I have changed a couple of things from previous post, but still does not work. win10
	LOCAL PD := .F.
	READYCAM()
		PD := .T.
		IF LSUCCESS == .F.
	IF LSUCCESS == .F.
		START PRINTDOC
		START PRINTPAGE
		PL := 8
		PL:= PL+20
	END PRINTPAGE
	END PRINTDOC
	IF PD = .T.
	PD := .F.
		ROW   10
		COL   7
		WIDTH 230
	END ACTIVEX
        ROW    5  //250
        COL    350  //120
        WIDTH  100
        HEIGHT 100   //28
        ACTION SNAPSHOT()
        CAPTION "Snap Shot"
		PICTURE 'CAMERA'
        FONTNAME "Arial"
        FONTSIZE 10
		*visible .F.
    END BUTTON
        ROW    160 //250
        COL    350   //170  //120
        WIDTH  100
        HEIGHT 100   //28
        CAPTION "Exit"
		PICTURE 'hp_close'
        FONTNAME "Arial"
        FONTSIZE 10
		*visible .F.
    END BUTTON
	CAMFORM.ACTIVATE
FUNCTION SNAPSHOT
PLAYBEEP()
CAMFORM.RELEASE
FUNCTION WEBCAM
<html>
		</body>
</html>
ENDTEXT
Franco
Posted: Thu Nov 28, 2019 1:43 am
by AUGE_OHR
hi
franco wrote: Sat Nov 23, 2019 7:26 pm you will also need CAMERA.SWF in this folder
can you tell me please where do i get that Flash file :?:
Posted: Thu Nov 28, 2019 1:50 am
by franco
I no not know how to send links, but I type camera.swf in active topic search box and testcam.zip comes up and it is in there.
Posted: Thu Nov 28, 2019 1:59 am
by AUGE_OHR
franco wrote: Thu Nov 28, 2019 1:50 am I no not know how to send links, but I type camera.swf in active topic search box and testcam.zip comes up and it is in there.
THX
i found it in this Thread viewtopic.php?f=14&t=4862
Posted: Thu Nov 28, 2019 4:12 pm
by mustafa
Hola amigo Franco
He estado revisando tu Sample y lo he modificado
un poco, pero el resultado no me está gustando
demasiado y creo que la causa es por fichero
camera.swf que no está dando la calidad necesario
un fichero JPG generado al cargarlo con Pain Shop
me está dando este mensaje al intentar cargarlo
"Este no es un archivo válido JPEG-JFIF"
Solo no me está dando Error de está forma
mira--> HMG_PrintFile1.PDF
Hi friend Franco
I've been checking your Sample and I have modified it
a bit, but I don't like the result
too much and I think the cause is per file
camera.swf that is not giving the necessary quality
a JPG file generated when loaded with Pain Shop
You are giving me this message when you try to load it
"This is not a valid JPEG-JFIF file"
It's just not giving me Error this way
look -> HMG_PrintFile1.PDF
Mustafa :x :mrgreen:
Posted: Thu Nov 28, 2019 7:02 pm
by franco
Mustafa, Thanks for helping.
I have adjusted the code below. If print to file, print preview is wrong but pdf file is right.
If print to printer, printer is right pff will be wrong.
We must find out what the disk print does.
Also as I said before if I load the jpeg file with paint then just save it, it will be right. paint does something in the save.
	LOCAL PD := .F., LSUCCESS
		WEBCAM('WEBCAM','CAMERA.SWF','300','300')     //'230')
	READYCAM()
	IF MSGYESNO('Do You Want to Print to *** DISK***')    /// NEW ADDED DISK FROM PRINT PREVIEW
		PD := .T.
		SELECT  PRINTER DEFAULT TO LSUCCESS preview ;
	IF LSUCCESS == .F.
		START PRINTDOC
		START PRINTPAGE
		PL := 8
		PL:= PL+20
		IF FILE(getcurrentfolder()+'\test1.jpg')  //BT_BitmapSaveFile(hBitmap, cImageFileName )
			IF PD = .T.
				@ PL,10 PRINT IMAGE 'C:\TRYPD\TRYPD2\test.jpg' WIDTH 40 HEIGHT 80 TYPE jpg  STRETCH
				@ PL,10 PRINT IMAGE 'C:\TRYPD\TRYPD2\test.jpg' WIDTH 80 HEIGHT 60 TYPE jpg
	END PRINTPAGE
	END PRINTDOC
	IF PD = .T.
		EXECUTE FILE 'HMG_PRINTFILE.PDF '
	PD := .F.
		ROW   10
		COL   7
		HEIGHT 230      //300
		WIDTH 300        //230
	END ACTIVEX
        ROW    5  //250
        COL    350  //120
        WIDTH  100
        HEIGHT 100   //28
        ACTION SNAPSHOT()
        CAPTION "Snap Shot"
		PICTURE 'CAMERA'
        FONTNAME "Arial"
        FONTSIZE 10
		*visible .F.
    END BUTTON
        ROW    160 //250
        COL    350   //170  //120
        WIDTH  100
        HEIGHT 100   //28
        CAPTION "Exit"
		PICTURE 'hp_close'
        FONTNAME "Arial"
        FONTSIZE 10
		*visible .F.
    END BUTTON
	CAMFORM.ACTIVATE
FUNCTION SNAPSHOT
CAMFORM.CAPTURE('TEST.JPG',45,50,260,170)
PLAYBEEP()
copy file test.jpg to test1.jpg                                          //ADDED THIS NOT NEEDED JUST FOR CHECKING PHOTO
CAMFORM.RELEASE
FUNCTION WEBCAM
<html>
		</body>
</html>
ENDTEXT
This works but is not the right way to do things.
Thanks for help,
Franco
Posted: Fri Nov 29, 2019 2:07 pm
by mustafa
Hola amigo Franco
He seguido con las investigación he creado una pequeña
aplicación para imprimir PDF y veo que con fotos
normales se genera PDF --> 00004.jpg y 00005.jpg pero
con 00002.jpg generado con "camera.swf" si ves la
información en "Info_Image.jpg" 00002.jpg No tiene
Compresión ni Resolución , encambio el mismo fichero
Salvado como 00021.jpg con el Paint de Windows
ya tiene Compresión "JPEG,quality:95 y una Resolución
de 96x96 PPP
En mi Sample todos los ficheros se imprimen menos
el 00002.jpg que esta dando Error
Creo que el problema es "camera.swf" no la programación
Harbour-HMG
Hi friend Franco
I have continued with the research I created a small
application to print PDF and I see that with photos
Normal PDF is generated -> 00004.jpg and 00005.jpg but
with 00002.jpg generated with "camera.swf" if you see the
information in "Info_Image.jpg" 00002.jpg You do not have
Compression or Resolution, change the same file
Saved as 00021.jpg with Windows Paint
It already has Compression "JPEG, quality: 95 and a Resolution
96x96 PPP
In my Sample all files are Printed less
The 00002.jpg that is giving Error
I think the problem is "camera.swf" not programming
Harbour-HMG
Posted: Fri Nov 29, 2019 5:06 pm
by franco
Hi Mustafa, Did you try my last sample ?.
I am going to try and change all sizes to see what happens, like camera.swf 900,900 and capture 900 700.
I do not understand how all this works but I see in html at bottom exactfit and width=100% height=100%.
All the best,
Franco
