Ok Mol...
Good suggestion and make sense to have an .ini file instead of modifying the
running .exe file.
Any suggestion for the .ini file type ? text file ?
Thks n Rgds
Chang
Add some text in the exe file
Re: Add some text in the exe file
Just Hmg It !
TXT and as save as name.INI
- Claudio Ricardo
Hi...Any suggestion for the .ini file type ? text file ?
Example Config.ini file... if not exist, is created for Write_Ini function
PUBLIC pcFileIni := GetCurrentFolder () + "\Config.ini"
PUBLIC pnMainRowIni := 10 // First init value
PUBLIC pnMainColIni := 10 // First init value
Set Language To Spanish
Set CodePage To Unicode
Set Multiple Off
Set Century On
Set Date French
Set Decimals To 2
Set BrowseSync On
Set TooltipStyle Balloon
If File (pcFileIni)
Read_Ini ()
Else
Write_Ini ()
EndIf
Load Window Main
SetProperty ("Main" , "Col" , pnMainColIni)
SetProperty ("Main" , "Row" , pnMainRowIni)
Main. Activate
Function Read_Ini
BEGIN INI FILE pcFileIni
GET pnMainColIni SECTION "MAIN" ENTRY "ColIni"
GET pnMainRowIni SECTION "MAIN" ENTRY "RowIni"
END INI
Function Write_Ini
SET SECTION "MAIN" ENTRY "ColIni" TO pnMainColIni
SET SECTION "MAIN" ENTRY "RowIni" TO pnMainRowIni
END INI
Function Main_Button_Exit
pnMainColIni := GetProperty ( "Main" , "Col" )
pnMainRowIni := GetProperty ( "Main" , "Row" )
Write_Ini ()
Main. Release
but can save much more information.
This is the content of the example .ini file:
[MAIN]
ColIni=96
RowIni=18
Pd. Sorry for my bad english
See this example, but according to your goal, you don't need to read window parameters on the fly, just handle it when closing the window.
#define WM_MOVE 0x0003
#define WM_SIZE 0x0005
Local nFRow:=0, nFCol:=0, nFWidth:=400, nFHeight:=600, lCenter:=.T.
IF File("Config.ini")
Begin ini file ("Config.ini")
Get nFRow Section "FORM_1" ENTRY "Row"
Get nFCol Section "FORM_1" ENTRY "Col"
Get nFWidth Section "FORM_1" ENTRY "Width"
Get nFHeight Section "FORM_1" ENTRY "Height"
End Ini
lCenter:=.F.
EndIf
DEFINE WINDOW Form_1 AT nFRow, nFCol WIDTH nFWidth HEIGHT nFHeight TITLE 'Hello World!' MAIN ;
ON RELEASE SaveIni()
DEFINE STATUSBAR
STATUSITEM "Try moving or resizing this window"
END STATUSBAR
IF lCenter
CENTER WINDOW Form_1
CREATE EVENT PROCNAME MoveAndSizeForm_1() HWND Form_1.HANDLE
Function SaveIni()
Set Section "FORM_1" ENTRY "Row" To Form_1.Row
Set Section "FORM_1" ENTRY "Col" To Form_1.Col
Set Section "FORM_1" ENTRY "Width" To Form_1.Width
Set Section "FORM_1" ENTRY "Height" To Form_1.Height
End Ini
Function MoveAndSizeForm_1()
Local nMSG := EventMSG ()
Local xPos, yPos, nWidth, nHeight, nRow, nCol
IF nMSG == WM_MOVE .OR. nMSG == WM_SIZE
xPos := LOWORD(EventlParam())
yPos := HIWORD(EventlParam())
nWidth := Form_1.Width
nHeight := Form_1.Height
nRow := Form_1.Row
nCol := Form_1.Col
Form_1.StatusBar.Item(1):="Form_1 Row: "+StrZero(nRow,5,0)+" / Col: "+StrZero(nCol,5,0)+" | Width: "+StrZero(nWidth,5,0)+" / Height: "+StrZero(nHeight,5,0)+" | xPos: "+StrZero(xPos,5,0)+" / yPos: "+StrZero(yPos,5,0)
Hola and thousand thanks to Mr. Claudio Ricardo and Mr. edk
for the very useful code.
It solved my problem effectively.
But still i wonder :
1. why the ON MOVE event not build in the hmg ?
2. any documentation on the BEGIN INI statement ? or any others un-documented statements ?
3.. How can i make this ?
Thks n Rgds
Chang
3.
These users thanked the author edk for the post (total 2):
danielmaximiliano (Thu Mar 18, 2021 12:38 am) • andyglezl (Thu Mar 18, 2021 2:12 am)
Thks n Rgds
Chang
Just Hmg It !
- Claudio Ricardo
Hi...
Maybe no one needed to start an event when moving a window.1. why the ON MOVE event not build in the hmg ?
With this button:How can i make this ?
