IP address.
zolysoftsolutions
IP address.
Post by zolysoftsolutions »
Hello,
Is possibble to read the IP address allocated by ISP?
The internal IP address is in windows registry, but the external not.
I need to read to a variable in some way the IP address like the "whatismyipadress.com" retourned.
By example on local machine I have 192.168.1.6 and the IP allocated by ISP is 89.192.166.27 (retourned by whatismyipadress.com)
Zoli B.
_______________________________
Open eyes for you!
Re: IP address.
zolysoftsolutions wrote:Hello,
Zoli B.
Hi Zoli
First, happy birth day to you :)
38 is a good age, please yourself 8-)
Regarding your question :
We have a control @...IPADDRESS / DEFINE IPADDRESS control in HMG and two samples about it.
But sadly, I haven't any experience and I'm afraid that this isn't you are searching.
In other hand, as far as I know, under normal conditions, IP address of any machine is variable; for every Internet connection will be assigned a different address to your machine. For own a fixed IP adress you need to buy it.
Probably you know all of these; all my knowledge is this.
zolysoftsolutions
Re: IP address.
Hello Esgici,
Thank you for the wishes and for your replay.
Really this is the challenge, because the IP may vary.
But I solved at the moment in my beginner way:
- I made a PHP script. Here the IP is read and written into a text file on http
- Before I need to use the remote IP, I launch the script trough an activex control (create the file), I download the text file and I store the content of the file into a variable
- in this way my problem is solved, but I think somebody have a shorter and faster solution for this.
Zoli B.
Open eyes for you!
Re: IP address.
maybe try to catch tracert dos command and examine results this command sends to screen
jayadevu
Re: IP address.
Post by jayadevu »
Pls try the following working sample:
function main
   local cInternetIP := Ip_Externo()
   cInternetIP := iif("Site" $ upper(cInterNetIP),cInterNetIP,;
                      "Internet IP is:  "+cInterNetIP)
   if file("init.cld")
      REQUEST HB_GT_WIN_DEFAULT
   DEFINE WINDOW Win_1 ;
      WIDTH 300 ;
      HEIGHT 150 ;
      ICON INTERNETIPICON ;
      TITLE 'Internet IP Address' ;
      MAIN ;
      NOSIZE ;
      NOMAXIMIZE ;
      TOPMOST
      @ 30,25 LABEL label_1 of Win_1 VALUE cInternetIP ;
            WIDTH 250 ;
            BORDER ;
            BOLD ;
            font "Arial" SIZE 11 ;
            CENTERALIGN ;
            CLIENTEDGE ;
            TOOLTIP "Your internet IP"
      @ 80,90 BUTTON button_1 of Win_1 CAPTION "Ok " ACTION Win_1.Release ;
            TOOLTIP "Click OK to exit"
   Win_1.Center
   ACTIVATE WINDOW Win_1
return NIL
FUNCTION IP_EXTERNO()
   local url, html, vRet
   url := "http://checkip.dyndns.org/" //'http://meuip.datahouse.com.br/ automation.whatismyip.com/n09230945.asp'
   html:= ReadPage_ler( url )
   memowrit(GetMyDocumentsFolder()+"\InterNetIPInfo.html",dtoc(date())+" "+time()+" ["+html+"]")
   vRet := PegaIP_ex(html) //vRET:= html //
RETURN iif(empty(vRET),"Site Not Reachable!",vRet)
FUNCTION PegaIP_ex(cHtml)
   LOCAL Pos, PosF
   Pos := At(':', Upper(cHtml) )
   IF Pos < 1
      RETURN 0
  * Pos += Len('IP?')
   cHtml := subst( cHtml, Pos+1 )
   PosF := At('<',Upper(cHtml)) - 1
   cHtml := Subst(cHtml,1,PosF)
RETURN alltrim(cHtml)
FUNCTION ReadPage_ler( cUrl )
   LOCAL oUrl, oCli, cRes := ''
   BEGIN SEQUENCE
      oUrl = TUrl():New( cUrl )
      IF EMPTY( oUrl )
         BREAK
      oCli = TIpClientHttp():New( oUrl )
      IF EMPTY( oCli )
         BREAK
      oCli:nConnTimeout = 20000
      IF !oCli:Open( oUrl )
         BREAK
      cRes := oCli:Read()
      oCli:Close()
   END SEQUENCE
RETURN cRes
zolysoftsolutions
Re: IP address.
Hi jayadevu!
It works! Thank you very much.. is more simple and more proffesionist than my solution. : )
Zoli B.
Open eyes for you!
