Grid
tonton2
Has thanked: 16 times
Been thanked: 17 times
Grid
Post by tonton2 »
Change Grid to Browse :
I would like to change this example to grid to browse, thanks for your help
// Dynamic Display
bdDisplay_1 := { || This.CellValue }
bdDisplay_2 := { || HMG_UPPER(This.CellValue) }
bdDisplay_3 = { || This.CellValue }
bdDisplay_4 := { || This.CellValue }
bdDisplay_5 := { || This.CellValue }
bdDisplay_6 := { || This.CellValue }
bdDisplay_7 := { || This.CellValue }
bdDisplay_8 := { || This.CellValue }
// Grid Column Controls Definitions
aCtrl_1 := {'TEXTBOX','NUMERIC','999999'}
aCtrl_2 := {'TEXTBOX','CHARACTER'}
aCtrl_3 := {'TEXTBOX','NUMERIC','99999999.99'}
aCtrl_4 := {'TEXTBOX','NUMERIC','99999999.99'}
aCtrl_5 := {'TEXTBOX','NUMERIC','99999999.99'}
aCtrl_6 := {'TEXTBOX','NUMERIC','99999999.99'}
aCtrl_7 := {'TEXTBOX','NUMERIC','99999999.99'}
aCtrl_8 := {'TEXTBOX','NUMERIC','9999999.99'}
@ 10,10 GRID Grid_Creance ;
WIDTH 770 ;
HEIGHT 440 ;
HEADERS {'Code ','Noms','RESTE','Prix Total','T.V.A ','Avances','Autre Av','Represent.'} ;
WIDTHS {70,200,90,90,90,90,90,90};
VALUE { 1 , 1 } ;
justify {0,0,1,1,1,1,1,1};
COLUMNCONTROLS { aCtrl_1 , aCtrl_2 , aCtrl_3 , aCtrl_4 , aCtrl_5 , aCtrl_6, aCtrl_7, aCtrl_8} ;
ON HEADCLICK { { ||Index_Code()},{ ||Index_NOM()} , {||Index_Reste()} ,{ || Index_PTotal()} } ;
ROWSOURCE "CREANC" ;
COLUMNFIELDS { 'CODE' , 'NOM' , 'Prix_Total+TUGP-Avance-Avancheq-Represent' , 'PRIX_TOTAL' , 'TUGP', 'AVANCE' , 'AVANCHEQ','REPRESENT' } ;
ALLOWAPPEND ;
ALLOWDELETE ;
DYNAMICDISPLAY { bdDisplay_1 , bdDisplay_2 , bdDisplay_3 , bdDisplay_4 , bdDisplay_5 , bdDisplay_6 ,bdDisplay_7,bdDisplay_8 } ;
CREANCE_1.Grid_Creance.ColumnDYNAMICFORECOLOR (3) := { WHITE} // BLACK}
CREANCE_1.Grid_Creance.ColumnDYNAMICBACKCOLOR (3) := {|| GREEN} // PURPLE}
Grand merci a vous
L'Algerie vous salut
Y.TABET
Red2
DBs Used: DBF, FoxPro, Visual FoxPro
Has thanked: 61 times
Been thanked: 8 times
Post by Red2 »
Am I correct that you are displaying a .DBF? If so you might start with the following differences:
Change property "ColumnFields" to property "Fields" using your old "ColumnFields" values
Change property "RowSource" to property "WorkArea" using your old RowSource value.
I am not aware that there is a Browse control-type property similar to Grid's ColumnControls.
In my opinion a Browse's display has some tradeoffs as compared to Grid.
I hope that this helps some.
tonton2
Post by tonton2 »
Red2 wrote:
Mon Jan 18, 2021 4:42 pm
"ColumnControls. " that's what I'm looking for
Thank you my friend
Y.TABET
tonton2
Post by tonton2 »
it's good I found it, thank you all
Y.TABET
franco
Been thanked: 38 times
Post by franco »
I use browse for lookups, grids for working with, mainly because of browsing larges files and speed.
I will be reposting my tbrowse example.
But to this, I found something interesting. I could use the following in a browse which has the word grid in them and they still worked
FC21 and so on are the fields sent by parameters. There may have been an easier way to display this but this works for JUSTIFY in a 5 field browse.
JUSTIFY {IF(LEN(ALLTRIM(FC11))>0,(IF(VALTYPE(&FC11)<> 'N',GRID_JTFY_LEFT,GRID_JTFY_RIGHT)),NIL),;
			IF(LEN(ALLTRIM(FC21))>0,(IF(VALTYPE(&FC21)<> 'N',GRID_JTFY_LEFT,GRID_JTFY_RIGHT)),NIL),;
			IF(LEN(ALLTRIM(FC31))>0,(IF(VALTYPE(&FC31)<> 'N',GRID_JTFY_LEFT,GRID_JTFY_RIGHT)),NIL),;
			IF(LEN(ALLTRIM(FC41))>0,(IF(VALTYPE(&FC41)<> 'N',GRID_JTFY_LEFT,GRID_JTFY_RIGHT)),NIL),;
			IF(LEN(ALLTRIM(FC51))>0,(IF(VALTYPE(&FC51)<> 'N',GRID_JTFY_LEFT,GRID_JTFY_RIGHT)),NIL)}
All The Best,
Franco
Canada
