Page 1 of 2
The STATUSBAR control has a BUG
Posted: Sun Aug 18, 2019 1:21 pm
by huiyi_ch
各位大师,你们好,
近日我发现HMG(V3.4.4)中的STATUSBAR控件存在BUG,当我们不停地向STATUSBAR控件赋值时,程序所占有用的内存也在不断地增加!当你打开任务管理器可发现这一现象。请大家帮助我解决这一问题。
Dear masters,
Recently, I found a BUG in the STATUSBAR control in HMG(V3.4.4). When we keep assigning values to the STATUSBAR control, the memory occupied by the program keeps increasing!You can see this when you open task manager. Please help me solve this problem.
SET DATE ANSI
WIDTH 640 ;
HEIGHT 400 ;
TITLE 'Statusbar Keyboard Demo' ;
DEFINE STATUSBAR FONT 'Arial' SIZE 9
STATUSITEM "Statusbar Demo"
END STATUSBAR
define button bt_1
ROW 160
COL 270
WIDTH 100
HEIGHT 28
ACTION test_statusBar()
CAPTION "Test"
END button
CENTER WINDOW Form_1
function test_statusBar()
while 1=1
Form_1.StatusBar.Item(1):="I like HMG very much!"
hb_idlesleep(0.1)
do events
end
return
- test.jpg (77.88 KiB) Viewed 10963 times
Re: The STATUSBAR control has a BUG
Posted: Mon Aug 19, 2019 9:34 am
by dragancesu
Why loop WHILE 1=1 ???
Posted: Mon Aug 19, 2019 9:47 am
by huiyi_ch
为了证实这个控件存在的问题!
In order to verify the problem with this control!
Posted: Mon Aug 19, 2019 2:23 pm
by edk
Maybe try to use RELEASE MEMEORY
SET DATE ANSI
WIDTH 640 ;
HEIGHT 400 ;
END STATUSBAR
define button bt_1
ROW 160
COL 270
WIDTH 100
HEIGHT 28
CAPTION "Start"
END button
IF Form_1.bt_1.Caption = 'Stop'
Form_1.bt_1.Caption := 'Start'
Form_1.StatusBar.Item(1):=""
Form_1.bt_1.Caption := 'Stop'
while Form_1.bt_1.Caption = 'Stop'
Form_1.StatusBar.Item(1):="I like HMG very much! " + time()
RELEASE MEMORY
HB_ReleaseCPU()
hb_idlesleep(0.1)
do events
end
RELEASE MEMORY
HB_ReleaseCPU()
return
Posted: Mon Aug 19, 2019 10:51 pm
by huiyi_ch
EDK老师,您好,
我测试了您修改过的程序。长时间运行程序,再也没有发现程序占用内存增加的问题。
您是一个计算机方面的天才!谢谢!
我很喜欢HMG,经常使用它编写一些小程序。但现在HMG处于无人维护的阶段。我发现您完全可以胜任优化完善HMG的工作。
Dear Mr. EDK,
I tested your modified program.Run the program for a long time, and no more increase in memory usage.
You are a computer genius!Thank you very much!
I love HMG and often use it to write small programs.But HMG is now in a state of unattended maintenance.I find that you are fully qualified to optimize HMG.
Posted: Tue Aug 20, 2019 3:20 pm
Edward,
Is it a good idea to install a timer (every 10 minutes or so) which will do a RELEASE MEMORY and HB_ReleaseCPU() ?
Posted: Thu Aug 22, 2019 1:19 am
by huiyi_ch
Edward及各位老师,
使用RELEASE MEMORY是解决StatusBar的权宜之计,同时,在线程中使用RELEASE MEMORY会出现意想不到的问题。所以请大师们从根本上解决StatusBar存在的问题。另外,MINIGUI中的StatusBar控件没有内存增加的问题。
Dear Mr. EDK and the Teachers ,
The use of RELEASE MEMORY is an expedient solution to StatusBar. At the same time, the use of RELEASE MEMORY in threads can cause unexpected problems. So please the masters to fundamentally solve the problems in StatusBar. In addition, the StatusBar control in MINIGUI has no memory gain problem.
Posted: Sun Aug 25, 2019 12:08 am
by huiyi_ch
Hello Grigory,
the StatusBar control in MINIGUI has no memory leak problem! Please you help solve the problems if possible.
Posted: Mon Aug 26, 2019 10:03 am
by huiyi_ch
Hello guys,
After experiment, StatusBar control memory leak exists only in the Unicode Library of hmg.3.4.4, and no problem is found in the ANSI library of hmg.3.4.4.
Posted: Thu Jul 02, 2020 6:37 am
by huiyi_ch
srvet_claudio教授您好,
看到您又出现在论坛上,我非常高兴和激动!我觉得HMG又有希望了。在使用HMG的过程中,我发现statusbar control有一个BUG,并发贴到群里寻求解决,但问题一直悬而未决。请老师帮助这个问题。
I am very happy and excited to see you on the forum again! I think THERE's hope for HMG again. In the process of using HMG, I found a BUG in statusBar Control and posted it to the group for resolution, but the problem remained unresolved. Ask the teacher to help with this problem. Thank you very much!
huiyi_ch wrote: ↑Sun Aug 18, 2019 1:21 pm
各位大师,你们好,
Dear masters,
SET DATE ANSI
WIDTH 640 ;
HEIGHT 400 ;
END STATUSBAR
define button bt_1
ROW 160
COL 270
WIDTH 100
HEIGHT 28
CAPTION "Test"
END button
while 1=1
hb_idlesleep(0.1)
do events
end
return
