Page 4 of 7
Re: HMG New Version in GitHub
Posted: Mon Jul 27, 2020 1:30 pm
by bpd2000
Rathinagiri wrote: Mon Jul 27, 2020 12:49 pm If you are sure enough your code is good, you can submit here also. I will try to review and submit myself.
Hi
Everybody face same problem
I suggest to start new thread, where user submit code and as suggested you
Code can be uploaded by you after verification
Also add Quick link for GitHub on Home page
Posted: Mon Jul 27, 2020 9:38 pm
by trmpluym
Maybe also include the suggestions in:
http://hmgforum.com/viewtopic.php?f=43&t=5537
Posted: Mon Jul 27, 2020 10:15 pm
by salamandra
trmpluym wrote: Mon Jul 27, 2020 9:38 pm Maybe also include the suggestions in:
Posted: Mon Jul 27, 2020 11:12 pm
by AUGE_OHR
when start with HMG i had some Problem with 32 Bit Unicode Debugger so i enhance it to work "for me"
i have document it here http://hmgforum.com/viewtopic.php?f=12&t=6173&p=59887
i normal work under 32 Bit were i had Problem with HMG Debugger.
i also have 64 Bit, using multi-boot, but i don´t use it often.
when working under 64 Bit "Original" Debugger do not crash :o
so Problem with Array might be only on 32 Bit OS :roll:
many enhancement like ON DBLCLICK "does not hurt" but some Modification might be wrong (but do not crash anymore)
DBGGUI.PRG
add ON DBLCLICK OnKeyPress( VK_RETURN ); in line 280, 308 , 326, 361, 388, 407, 421
add ON DBLCLICK OnKeyPress_DisplayVars( VK_RETURN, cFormName, cGridName, xVarValue, aObjRawValue, aColor ) ; in line 672
line 1254
PROCEDURE UpdateGridVars()
aVars := HMG_Debugger():GetVars( @aBVars )
i had Problem with
nValue := _HMG_FormDebugger.Grid_Vars.VALUE
which sometimes are > LEN(aVars) so it crash :(
so please revise UpdateGridVars() if i misunderstood concept
DBGHB.PRG
modify METHOD GUIDoEvents() by add BEGIN SEQUENCE / END SEQUENCE
FUNCTION __dbgValToStr( uVal )
CASE cType == "B" ; RETURN hb_valToExp ( uVal )  // "{|| ... }"
modify METHOD GetVars() by add BEGIN SEQUENCE / END SEQUENCE
add aVars := {}
same Problem like in UpdateGridVars() with LEN(Array)
i have change it to "do not crash" but not sure if i´m misunderstood Concept
hope it is useful to update HMG
HMG_Debugger2.zip
(24.17 KiB) Downloaded 1422 times
Posted: Tue Jul 28, 2020 5:35 am
by AUGE_OHR
Request : build.bat / build64.bat
i like use build.bat / build64.bat in CMD Box
when start Original build.bat / build64.bat it will add Path ... each time :roll:
SET HMGPATH=%~dp0
rem ******************************************************************************
rem SET BINARIES PATHS
rem PROCESS PARAMETERS
rem
rem /n no run after build
rem /d enabled debugger
rem /c console mode
this Version only add Path once :D
SET HMGPATH=%~dp0
path|find /i "%HMGPATH%\harbour\bin" >nul || GOTO SETPATH
GOTO NEXTSTEP
:SETPATH
rem
rem /c console mode
:NEXTSTEP
Posted: Sun Oct 11, 2020 7:40 pm
by Carlos Britos
I have created in github some scripts to compile official HMG and the different forks using github actions.
In the following link you can see them.
https://github.com/asistex/HMG/tree/master/workflows
I hope it will be useful for everyone.
Hola,
He creado en github algunos script para compilar HMG oficial y los diferentes forks usando github actions.
En el siguiente link pueden verlos.
Espero que sea de utilidad para todos.
Greetings
Carlos
Posted: Mon Oct 12, 2020 1:18 am
by apais
Carlos.
Diego y yo ya habíamo hecho lo mismo hace unas semanas.
Pero a nadie pareció importarle.
Mi link: https://github.com/apais/hmgbinaries
Espero que alguien lo integre en el github de HMG algún día.
Posted: Thu Oct 22, 2020 4:27 am
by bpd2000
Add Quick link for GitHub on Home page
Posted: Thu Oct 22, 2020 8:04 am
by ASESORMIX
Is VERY important for my.
Thank you.
Posted: Thu Oct 22, 2020 10:08 am
by huiyi_ch
Thank you
