Harbour MiniGUI Extended Edition build 21.02 is published
Hi Friends,
Edition.
Here's a breakdown of some of the modifications in the build 21.02.
* Fixed a program crash on exit from the EDIT EXTENDED command
at using of LetoDBf server.
* The colored TAB control with HOTTRACK clause allows to modify
the HTFORECOLOR and HTINACTIVECOLOR properties at runtime.
* The Grid control supports the optional ON RCLICK clause.
This clause specifies the action at the mouse right button click.
* Added 'RowsPerPage' property which retrieves the number of
rows visible within a Grid.
Note: This property is read-only and available after a control
definiton only.
* The MiniGUI core libraries were compiled with the Harbour switch
-l for a smaller program size.
* Updated Harbour Compiler 3.2.0dev to a recent Git-version.
* Added the new interesting samples.
* Updated SQLite3 library and some examples.
There are also many internal modifications for the UNICODE
implementation in the MiniGUI core (work in progress).
A setup of the build 21.02 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
[MiniGUI Team]
Anand
Re: Harbour MiniGUI Extended Edition build 21.02 is published
Post by Anand »
Hi Grigory ,
Thank you for the update and double thank you for " UNICODE (work in progress)" :D
Anand
Anand
Thanks Grigory !!!
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Thank you Very much Grigory !!!
Salamandra, Brazil
quartz565
Post by quartz565 »
Thank you Grigory !
Nikos.
os: Windows Server 2019 - 64
Gracias Grigory.
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Thanks Grigory !
