Harbour MiniGUI Extended Edition build 20.08 is published
Re: Harbour MiniGUI Extended Edition build 20.08 is published
Thanks for the update.
Anand
Anand
- DBs Used: Visual FoxPro, FoxPro
Thank you Grigory!
I've uploaded the updated setup of the build 20.08 for Borland C++ 5.8.2 at
Whatsnew:
Thanks for your attention and support.
Best Regards,
[MiniGUI Team]
Whatsnew:
There is a "last-minute" improvement also:* Fixed: The default backcolor of Label, CheckBox and RadioGroup controls
is not correct if you place a WINDOW PANEL into the TAB control.
Contributed by Grigory Filatov <gfilatov@inbox.ru>
(see demo2.prg in folder \samples\Basic\CONTAINERS\Panel)
* Fixed: Wrong GETBOX update behavior when user entered an invalid date
value (there is no way to correct it via program action).
Bug was reported by Pierpaolo Martinello.
* Enhanced: The DATEPICKER supports the colors definition for a dropdown
MonthCalendar in the THEMED Operating Systems.
It was a postponed user's request.
Based upon a contribution of HMG user Jimmy.
Adapted for Minigui Extended by Grigory Filatov <gfilatov@inbox.ru>
(see demo.prg in folder \samples\Basic\DatePicker)
* Enhanced: The MONTHCAL control allows the display of days in BOLD.
There are three auxiliary functions for above feature handling:
- AddMonthCalBoldDay( ControlName, ParentName, dDate );
- DelMonthCalBoldDay( ControlName, ParentName, dDate );
- IsMonthCalBoldDay( ControlName, ParentName, dDate ).
Based upon a code borrowed from OOHG.
(see month.prg in folder \samples\Basic\MONTHCAL)
* New: 'Testing columns in Tsbrowse for DBF file' sample.
Contributed by Sergej Kiselev and Verchenko Andrey
(see in folder \samples\Advanced\Tsb_2tables)
* New: 'Virtual columns in Tsbrowse for DBF file' sample.
(see in folder \samples\Advanced\Tsb_VirtualColumn)
* Updated: 'Month calendar control test' sample.
(see demo.prg in folder \samples\Basic\MONTHCAL)
The upgrade to this build is recommended.* Enhanced: The MONTHCAL control will be adjusted correctly by width and
height after assigning a FontName and/or FontSize at runtime.
Best Regards,
[MiniGUI Team]
- salamandra
- DBs Used: DBF, MySQL, SQL
Hi Grigory,
Thank you very much for this update.
Salamandra, Brazil
Salamandra, Brazil
Thank you very much Grigory!
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
Anand
Anand
Whatsnew:
Best Regards,
[MiniGUI Team]
Whatsnew:
The upgrade to this build is recommended.* Updated: The internal function GetUserControlType() detects now a new
RichEditBoxEx control.
* Updated: Revised MiniGUI core code for compiling a lite English only
version of the library with the following switches in the header
file include\minigui.ch:
- _MULTILINGUAL_ constant is turned OFF;
- _PROPGRID_ constant is turned OFF;
- _PANEL_ constant is turned OFF;
- _PAGER_ constant is turned OFF;
- _HMG_COMPAT_ constant is turned OFF;
- _OBJECT_ constant is turned OFF.
* Updated: HMGS-IDE v.1.4.4.2 Project Manager and Two-Way Visual Form Designer:
- experimental build with the lite version of MiniGUI 20.08.
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- added the ADS field types support in the method :LoadFields().
Contributed by Igor Nazarov.
* Updated: ADS RDD synced for the latest Advantage Database Server 12.0.
* New: 'Tsbrowse ADO Test' sample.
(see in folder \samples\Advanced\Tsb_adotest)
* Updated: 'Test Directory List with System Icons' sample:
- fixed memory leak which was reported by Jimmy.
(see in folder \samples\Advanced\FILEICON)
* Updated: 'TBrowse speed test with multiple fields' samples:
- added the hotkey actions via Ctrl + 0...8.
(see in folder \samples\Advanced\Tsb_MoreFields)
Best Regards,
[MiniGUI Team]
Anand
Anand
Thank you for the update Grigory!
Best Regards,
Nikos.
Nikos.
- salamandra
Hi Grigory,
Thank you very much for this new update!!
by the way, any idea of when minigui will be ready for unicode?
Salamandra, Brazil
Salamandra, Brazil
