Harbour MiniGUI Extended Edition build 20.06 is published
Hi Friends,
Edition.
Here's a breakdown of some of the modifications in the build 20.06.
* Fixed: When loads a Grid control and 'ColumnControls' property
is NIL then converts automatically any data type in a text type
(introduced in the build 20.01 (update 3)).
* Fixed: The back color of a TAB control was not changed at runtime.
* Pacified the C-warning "cast-function-type" in the MiniGUI core
(was passed MinGW GNU C 10.1).
* Added the useful function HMG_SetMenuTheme() for setting of the
predefined menu themes.
* A TREE control color was improved for loading a bitmap with
a color depth 8 bpp. It is compatible with the Official HMG.
* An old behavior of 'OnChange' event was restored in a Browse
control (a new behavior was introduced in the build 19.12).
It uses SET BROWSEUPDATEONCLICK ON command for a backward
compatibility with an old code.
* Synchronized Extended HMG for compatibility with Official HMG:
- New: function GetFormNameByHandle( hWnd, @cFormName, ;
@cFormParentName ) --> Return nFormIndex;
- New: function GetControlNameByHandle ( hWnd, @cControlName, ;
@cFormParentName ) --> Return nControlIndex.
* Modified the application manifest for compatibility with a recent
heap implementation in Windows 10 (‘heapType’ element).
This feature is supported in Windows 10, version 2004, and later.
* Added the new library HbCrypto (borrowed from Harbour 3.4 fork).
* Updated BosTaurus, Debugger, MiniPrint, HMG_HPDF, TSBrowse and
Sqlite3 libraries.
* Updated the some Basic and Advanced samples.
A setup of the build 20.06 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 20.06 is published
Thanks Grigory !
Please note that there are also the private MiniGUI builds for the following
free C-compilers:
- MinGW GNU C 10.1.1 (32-bit);
Minigui Ex Package (build date: 29.06.2020)
Download links: http://hmgextended.com/files/PRIVATE
Components versions:
Harbour MiniGUI Extended Edition 20.06 (Release)
Harbour 3.2.0dev (r2004201301)
Harbour Make (hbmk2) 3.2.0dev (r2020-04-20 13:01)
gcc (GCC with MCF thread model, built by LH_Mouse.) 10.1.1 20200605
- MinGW GNU C 10.1.1 (64-bit);
Minigui Ex 64 Package (build date: 29.06.2020)
Harbour 3.4.0dev (cf51c11) (2017-12-20 13:44)
Harbour Make (hbmk2) 3.4.0dev (cf51c11) (2017-12-20 13:44)
gcc (MinGW-W64 x86_64-posix-seh, built by Brecht Sanders) 10.1.1 20200606
- MS Visual C++ 2019 (32-bit);
- MS Visual C++ 2019 (64-bit).
Copyright (c) 1999-2020, https://harbour.github.io/
Harbour Build Info
Version: Harbour 3.2.0dev (r2004201301)
Compiler: Microsoft Visual C++ 19.26.28806 (32-bit)
Platform: Windows 10 10.0
PCode version: 0.3
ChangeLog last entry: 2020-04-20 15:01 UTC+0200 Przemyslaw Czerpak (druzus/at/poczta.onet.pl)
ChangeLog ID: e8cc50254a83714ccb22e78db84a492a419aa576
Built on: Jun 3 2020 12:37:53
Extra Harbour compiler options: -gc0
Extra C compiler options: -DHB_GC_AUTO -DHB_GUI -DHB_NO_TRACE -DHB_MEMO_SAFELOCK
Build options: (C++ mode) (Clipper 5.3b) (Clipper 5.x undoc)
Thanks for your attention. :)
[MiniGUI Team]
quartz565
Post by quartz565 »
Thanks Grigory !
Nikos.
os: Windows Server 2019 - 64
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
dragancesu wrote: Tue Jun 30, 2020 1:32 pm http://hmgextended.com/files/PRIVATE/ not work
Hi Dragan,
Thanks fo your interest :!:
An access is forbidden for unauthorized users (for the donators is open :arrow:).
Anand
Post by Anand »
Thank you for the enhancements.
Anand
Anand
vlademiro
Post by vlademiro »
Hi Grigory
At hmgextended.org I found the donation link.
I wonder how the rest of the process will go.
Should I send an email stating?
Could you tell me the details?
I was interested.
Thank you
vlademiro wrote: Tue Jun 30, 2020 5:42 pm Hi Grigory
I was interested.
HI Vlademiro,
Thanks for your interest.
If you wish to express your appreciation for the time and resources that I have expended at
developing and supporting MiniGUI Extended, I accept and very appreciate the monetary donations.
If you wish to make one, you can do it via PayPal.
To make the donation, simply do a transfer to:
EMail: o.g.filatova@gmail.com
Please send the Sender First and Last Name, your Country/City and
the amount of your donation to gfilatov@inbox.ru optionally.
If you want also I'll send you a confidential link to MinGW-based distribution (as a bonus).
Thanks in advance :!:
Hi Vlademiro,
I'm very appreciate your support in this hard time. :arrow:
