Harbour MiniGUI Extended Edition build 20.08 is published
Anand
Re: Harbour MiniGUI Extended Edition build 20.08 is published
Post by Anand »
Thanks for the update.
Anand
Anand
Red2
Post by Red2 »
Thank you Grigory!
gfilatov
Post by gfilatov »
I've uploaded the updated setup of the build 20.08 for Borland C++ 5.8.2 at
Whatsnew:
* Fixed: The default backcolor of Label, CheckBox and RadioGroup controls
is not correct if you place a WINDOW PANEL into the TAB control.
Contributed by Grigory Filatov <gfilatov@inbox.ru>
(see demo2.prg in folder \samples\Basic\CONTAINERS\Panel)
* Fixed: Wrong GETBOX update behavior when user entered an invalid date
value (there is no way to correct it via program action).
Bug was reported by Pierpaolo Martinello.
* Enhanced: The DATEPICKER supports the colors definition for a dropdown
MonthCalendar in the THEMED Operating Systems.
It was a postponed user's request.
Based upon a contribution of HMG user Jimmy.
Adapted for Minigui Extended by Grigory Filatov <gfilatov@inbox.ru>
(see demo.prg in folder \samples\Basic\DatePicker)
* Enhanced: The MONTHCAL control allows the display of days in BOLD.
There are three auxiliary functions for above feature handling:
- AddMonthCalBoldDay( ControlName, ParentName, dDate );
- DelMonthCalBoldDay( ControlName, ParentName, dDate );
- IsMonthCalBoldDay( ControlName, ParentName, dDate ).
Based upon a code borrowed from OOHG.
(see month.prg in folder \samples\Basic\MONTHCAL)
* New: 'Testing columns in Tsbrowse for DBF file' sample.
Contributed by Sergej Kiselev and Verchenko Andrey
(see in folder \samples\Advanced\Tsb_2tables)
* New: 'Virtual columns in Tsbrowse for DBF file' sample.
(see in folder \samples\Advanced\Tsb_VirtualColumn)
* Updated: 'Month calendar control test' sample.
(see demo.prg in folder \samples\Basic\MONTHCAL)
There is a "last-minute" improvement also:
* Enhanced: The MONTHCAL control will be adjusted correctly by width and
height after assigning a FontName and/or FontSize at runtime.
Thanks for your attention and support.
Best Regards,
[MiniGUI Team]
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi Grigory,
Thank you very much for this update.
Salamandra, Brazil
quartz565
Post by quartz565 »
Thank you very much Grigory!
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Anand
Post by Anand »
Anand
Anand
gfilatov
Post by gfilatov »
Whatsnew:
* Updated: The internal function GetUserControlType() detects now a new
RichEditBoxEx control.
* Updated: Revised MiniGUI core code for compiling a lite English only
version of the library with the following switches in the header
file include\minigui.ch:
- _MULTILINGUAL_ constant is turned OFF;
- _PROPGRID_ constant is turned OFF;
- _PANEL_ constant is turned OFF;
- _PAGER_ constant is turned OFF;
- _HMG_COMPAT_ constant is turned OFF;
- _OBJECT_ constant is turned OFF.
* Updated: HMGS-IDE v.1.4.4.2 Project Manager and Two-Way Visual Form Designer:
- experimental build with the lite version of MiniGUI 20.08.
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- added the ADS field types support in the method :LoadFields().
Contributed by Igor Nazarov.
* Updated: ADS RDD synced for the latest Advantage Database Server 12.0.
* New: 'Tsbrowse ADO Test' sample.
(see in folder \samples\Advanced\Tsb_adotest)
* Updated: 'Test Directory List with System Icons' sample:
- fixed memory leak which was reported by Jimmy.
(see in folder \samples\Advanced\FILEICON)
* Updated: 'TBrowse speed test with multiple fields' samples:
- added the hotkey actions via Ctrl + 0...8.
(see in folder \samples\Advanced\Tsb_MoreFields)
Best Regards,
[MiniGUI Team]
Anand
Post by Anand »
Anand
Anand
quartz565
Post by quartz565 »
Thank you for the update Grigory!
Best Regards,
Nikos.
salamandra
Hi Grigory,
Thank you very much for this new update!!
by the way, any idea of when minigui will be ready for unicode?
Salamandra, Brazil
