Hello all,
I am new to HMG but Clippering since 1987...
I have some large applications in Clipper 5.2 and I am now rewriting most of it in HMG. All this goes very well !
But I have a problem/question: is there a way to FTP files to a website. I am now using DOS ftp and this not an
a certain/secure method. I read about COM_ functions and OPEN CONNECTION but I can't find documentation or samples.
Anybody any suggestions?
Regards and thanks,
Serge/Belgium
FTP and COM_ functions
Re: FTP and COM_ functions
Hi serge_girard,
Try hbtip library.
For ftp
Try hbtip library.
For ftp
#require "hbtip"
PROCEDURE Main( cUrl )
LOCAL oCon, oUrl
oUrl := TUrl():New( cUrl )
IF Empty( oUrl )
? "Invalid url " + cUrl
QUIT
IF oUrl:cProto != "ftp"
? "This is a 'DELE' test for ftp."
? "Use an ftp address with a file that you can delete."
QUIT
oCon := TIPClientFTP():New( oUrl )
oCon:nConnTimeout := 20000
? "Connecting with", oUrl:cServer
IF oCon:Open( cUrl )
? "Connection eshtablished"
? "Deleting", oUrl:cPath
IF oCon:CWD( oUrl:cPath )
? "CWD success"
IF oCon:Dele( oUrl:cFile )
? "DELE success"
? "DELE Faliure (server reply:", oCon:cReply + ")"
? "CWD Faliure (server reply:", oCon:cReply + ")"
oCon:Close()
? "Can't connect with", oUrl:cServer
IF oCon:SocketCon == NIL
? "Connection not initiated"
ELSEIF hb_inetErrorCode( oCon:SocketCon ) == 0
? "Server sayed:", oCon:cReply
? "Error in connection:", hb_inetErrorDesc( oCon:SocketCon )
? "Done"
Oleksandr Antypenko
xHarbour 1.2.3 , Harbour 3.x + Mingw 4.x (HMG, minigui)
https://bitbucket.org/aantypenko
https://github.com/aantypenko
Oleksandr Antypenko
The Santy friend forgot to say that if you need to secure tasacciones have to use the library hbtip with SSL support
Openssl need to download and install in c:\openssl
if using FTPS:// need some more changes.
http://en.wikipedia.org/wiki/FTPS
Thank you danielmaximiliano
Oleksandr Antypenko
Oleksandr Antypenko
Thx both,
In the example of Santy I get an error (IF oUrl:cProto != "ftp" -->Use an ftp address with a file that you can delete)
I made a FTP:ftp.xxxxx.xx folder.
Do I need something else?
Thx,S
Thx,S
I found a good solution on
http://www.creasolgroup.com/xOraclipLan ... _f.en.html
Topic can be closed.
Thx all,
Thx all,
