i have see TSbrowse() and know native Listview using Ownerdraw / CustomDraw.
but for Calendar i prefer a "fix Grid".
a Day have only 24 hour so ROW or COL are "fixed" and "no browse" are need "to scroll"
i use Time as ROW as Outlook Calendar does it.
also DBF Sturcture is made for MAPI so i can "sync" Calendar Data "on-fly"
the Problem was to "simulate" a Grid so when DragDrop LABEL it will "snap to Grid" to get right ROW / COL.
as you see i can change Display to show 1 / 5 / 7 or 14 Days. i take much more Time to Add/Del Column in Browse.
so i "think" a "fixed Grid" is better for Calendar.
Grid with multilines? Is it possible?
- AUGE_OHR
Re: Grid with multilines? Is it possible?
I do not know if this will work for you, but what I did was.
The field description in my table was 25 characters. So I added a field longdesc, C,80,0
It is a textbox out outside at the bottom of the grid. What my clients use it for is if 25 characters are not enough. It gets refreshed and saved
the same a the fields in the grid. If there is something in the longdesc, when printing it prints on the line after the grid fields and before next
grid Line. I don`t know how much you want to add but 2 of these fields could hold a lot of information.
I use this on a sales invoice. The line would be 1 line above your sub total line on your invoice.
All The Best,
Franco
Canada
Franco
Canada
- AUGE_OHR
in a GRID each CELL have same height.
you can "init" GRID with big Font an change after create to normal Font to get "more Space" for "multi-line" Text.
using Ownerdraw , with LVS_OWNERDRAWFIXED, you get WM_MEASUREITEM and WM_DRAWITEM Message
using MEASUREITEMSTRUCT() you can "manipulate" Size of Cell
using DRAWITEMSTRUCT() you get all Information to "paint"
but the "Problem" is : how can User use Callback Slot
under Xbase++ i can use a Callback Slot with Codeblock
::oPresspace is use by Xbase++ to "paint" , Windows API can use HDC of DRAWITEMSTRUCT
so it is possible but much more Work than using LABEL for Calendar.
CASE nMsg == WM_MEASUREITEM
::My_MEASUREITEM(wp,lp)
RETURN 1
CASE nMsg == WM_DRAWITEM
::My_DRAWITEM(wp,lp)
RETURN 1
INLINE METHOD My_MEASUREITEM(wp,lp)
cCaption := ::lv_GetItemText(::oMeasureitemstruct:itemID+1) // zero-based
aTextSize := ::GetTextExtentPoint(cCaption)
::aDims := { ::oMeasureitemstruct:itemWidth ,;
::oMeasureitemstruct:itemHeight }
nWidth := MAX(::aDims[1],aTextSize[1])
nHeight := MAX(::aDims[2],aTextSize[2])
::oMeasureitemstruct:itemWidth := nWidth
::oMeasureitemstruct:itemHeight := nHeight
// if User have set Codeblock in o:drawItem Slot
IF VALTYPE( ::drawItem ) == "B"
// first 4 same as Xbase++ aInfo Array
aInfo := { ::oDrawItemStruct:itemID+1 ,; // XBP_DRAWINFO_ITEM zero-based
::oDrawItemStruct:itemAction ,; // XBP_DRAWINFO_ACTION
::oDrawItemStruct:itemState ,; // XBP_DRAWINFO_STATE
{::oDrawItemStruct:rcItem:Left, ::oDrawItemStruct:rcItem:Top, ::oDrawItemStruct:rcItem:Right, ::oDrawItemStruct:rcItem:Bottom },;
NIL ,; // XBP_DRAWINFO_AREA
::nColCount ,; // XBP_DRAWINFO_COLUMN
::oDrawItemStruct:hDC ,; // XBP_DRAWINFO_HDC
::oDrawItemStruct:hwndItem } // XBP_DRAWINFO_HWND
EVAL( ::drawItem, ::oPresspace , aInfo , Self)
- AUGE_OHR
https://www.hmgforum.com/viewtopic.php?t=6335&p=61059
other Sample hereyou can "init" GRID with big Font an change after create to normal Font to get "more Space" for "multi-line" Text
